da tranny question
so i searched but didnt find anything about changing tranny fluid. i have a DA and i needa change the fluid. anyone know of a write up for doin this. maybe one that shows where to fill and where the drain bolt is. i cant find my shop manual
The drain bolt is in the lower part of the tranny case on the passenger side, its a bolt that has a 3/8" hole that a ratchet will fit in to break the bolt loose. The fill bolt is on the same side but by where the axle comes out of the case, the bolt for that is a 17mm bolt that you need to take out and however you can figure it out to pump the fluid back into the fill hole. Pump til it starts coming out of the fill hole. It's full when the fluid is at the bottom of the fill hole(when it's done dripping out of the fill hole basically).
inscape
Jan 21, 2005 12:27 PM
ocdcivic
Dec 11, 2004 10:11 AM
2lobes1engine
26
Jun 29, 2004 08:27 PM
