b16 or gsr tranny?
Old Aug 7, 2007 | 12:45 AM
91redteg's Avatar
Default b16 or gsr tranny?
im lookin for a new tranny for my da. just lookin for opinions. gsr or b16? and how will i kno if its a good tranny im buying. is there anyway to tell if its gonna have grinds or anything?
Old Aug 7, 2007 | 09:28 PM
91redteg's Avatar
Default Re: b16 or gsr tranny? (91redteg)
bump
Old Aug 7, 2007 | 09:54 PM
davidluko's Avatar
It's up to you to decide, would you rather have a little more performance or a little better gas milage? The B16 tranny will accelerate quicker but get worse gas milage since the RPMs will be up higher, especially on the freeway. As far as grinds and things like that, there's no way to tell unless you testdrive the tranny or rip it apart and check all the synchros/bearings/clearances.
Old Aug 7, 2007 | 10:08 PM
deegz's Avatar
not to mention trying to find a cable gsr tranny...
I recommend you rebuild your tranny and put a different final drive in it if you want to go faster, not to mention the peice of mind knowing you have a new tranny...dont make the same mistake i did, taking someones word that it was rebuilt less than 5000 miles ago, if you do, get the paper work to confirm it, still you dont know how hard it has been beatin on in those miles...
anyone that is selling gsr or b16 tranny knows that they are prime time trannys, so they know the value is good whether its been beat up or not, and if they can jip you for another 300 dollars telling you its been rebuilt....
Dont go cheap, or you will regret it, you will find this out over time....if you do, in the end you be putting out more denero.
Old Aug 7, 2007 | 11:19 PM
davidluko's Avatar
True, it's hard to trust anyone nowadays when it comes to Hondas and cars in general and used parts... ripping someone off on a tranny is super easy, if it's out of the car and not taken apart there's no way you can tell anything about it at all. It does get expensive to rebuild it though. What I think might be a good way to go is reuse your stock tranny, get a blown Si or GSR tranny that still has good gears, and buy new synchros, then put the synchros and gears into your stock tranny.
Old Aug 7, 2007 | 11:24 PM
91redteg's Avatar
Default Re: (Hatch_R)
thanx
Old Aug 7, 2007 | 11:37 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: (91redteg)
B16...
Old Aug 8, 2007 | 12:23 AM
fknowned's Avatar
b16 trannys suck gears are to short ls is the way to go
Old Aug 8, 2007 | 12:24 AM
Byaaah!'s Avatar
Default Re: (fknowned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fknowned &raquo;</TD></TR><TR><TD CLASS="quote">b16 trannys suck gears are to short ls is the way to go </TD></TR></TABLE>
Good point, but I guess he prefers GSR or B16...
LS is the way to go though...
fknowned's Avatar
not to forget finding a cable b16 or gsr is pretty hard
Old Aug 8, 2007 | 01:40 AM
davidluko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project95LS-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
LS is the way to go though...</TD></TR></TABLE>
If you know nothing about cars (at all, in general), please don't post. There IS a reason why B16 and GSR trannies are way more popular over LS ones... because the gearing is shorter which means faster acceleration. Did you guys think that through at all?
Old Aug 8, 2007 | 02:04 AM
SIC_jdm_da9's Avatar
i have LS right now and its good for me but that is with my flywheel and clutch but i would go SI but you will be burnin more gas... higher rpms
Old Aug 8, 2007 | 03:06 AM
integraslut78's Avatar
Default Re: (SIC_jdm_da9)
Depends what you want the tranny for, if it's for drag racing go with the B16 tranny and maybe swap in a LS 5th gear to help you out if it's your daliy driver for gas mileage.
Just my .02
Old Aug 8, 2007 | 06:42 AM
deegz's Avatar
im getting my stock gsr tranny rebuilt for 900, taken out, rebuilt and installed, im also having him put in a exedy stage 2 clutch and exedy 9.0lb flywheel that i purchased off ebay.
I went a little overboard with clutch and flywheel, but just for a basic rebuild it was 900, b16 trannys in good shape go for 750 all day long, gsr trannys are going for just a bit more, but your risking buying a bunk tranny
Old Aug 8, 2007 | 11:41 AM
davidluko's Avatar
I'd say B16 trannies are probably actually more expensive than GSR trannies because the gearing is even shorter (it's like an ITR tranny but without the LSD), and I usually see them both go anywhere from 550-700 completely stock. Basically to sum up the answer to the OP's question, we gave you some options but it's your choice to decice what you want and how much money you have, etc. Also like someone mentioned (about the LS 5th gear), my choice (if I had the money) would be to get an Si tranny, an aftermarket LSD, an LS 5th gear for freeway cruising, and a ~10lb flywheel with Exedy stage 2 clutch. But basically it's all up to personal preferance.
Old Aug 8, 2007 | 11:45 AM
dizzzane's Avatar
91redteg PM me if you are interested, we have a gsr cable tranny with low miles from Japan, only have one in though. or you can call us, number is in sig
Old Aug 8, 2007 | 12:26 PM
nicoya_hyphy@yahoo.com's Avatar
Default Re: (JDM_dc2_B18c)
b16 all the way
Old Aug 8, 2007 | 10:45 PM
91redteg's Avatar
Default Re: (nicoya_hyphy@yahoo.com)
um i want a tranny with shorter gears. was this a serious post?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">
If you know nothing about cars (at all, in general), please don't post. There IS a reason why B16 and GSR trannies are way more popular over LS ones... because the gearing is shorter which means faster acceleration. Did you guys think that through at all? </TD></TR></TABLE>
x2.
thanx for everything else tho i had talked to a guy i met on g2ic.com and we raced with pretty much the same setup but he has a b16 tranny and he beat me by a good amount. my clutch slips a little to so ive got it in my head now to replace the clutch and tranny. sounds like a b16 is what i want rebuilding is a little out of budget. ive also heard you lose initial torque with a lightened flywheel cuz it doesnt have as much rotating mass or something. anyone kno anything about that?
thanx again for all the response
Old Aug 8, 2007 | 11:04 PM
davidluko's Avatar
When you start off the line you do have to hit the gas harder with a lighter flywheel since it'll want to slow down a lot easier than a heavy flywheel when the clutch starts rubbing against it, but it'll make rev matching a lot easier which alone I think is enough reason to get one, plus it's supposed to help the engine rev up faster a little.
Old Aug 8, 2007 | 11:16 PM
91redteg's Avatar
yeah ive heard there more noticeably effective in roadracing cuz of the rev matching
db8geezer
Oct 18, 2005 12:21 PM
92-EG6
30
Mar 14, 2004 06:18 AM
