Reverse lights doesn't work!
Old Aug 6, 2007 | 11:43 PM
LiLaZnKiD51o's Avatar
Default Reverse lights doesn't work!
I did a gsr swap in my 99 civic coupe ex and now my reverse lights doesn't work. I checked the fuses and the light bulbs itself but nothings wrong with it. Any ideas on how to fix it?
Old Aug 6, 2007 | 11:45 PM
Syndacate's Avatar
Check the reverse light sensor - it's on the transmission, in the middle, on top.
Old Aug 7, 2007 | 07:28 PM
Default Re: (Syndacate)
I checked the sensor and it doesn't seem to be the problem.
Old Aug 7, 2007 | 08:19 PM
sageuvagony's Avatar
Default Re: (LiLaZnKiD51o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiLaZnKiD51o &raquo;</TD></TR><TR><TD CLASS="quote">I checked the sensor and it doesn't seem to be the problem.</TD></TR></TABLE>
Just how did you check it? Unplug that sensor and jump the 2 wires that connect to the sensor (not the 2 wires hanging off the sensor)
Old Aug 7, 2007 | 08:47 PM
Tjames8864's Avatar
Default Re: Reverse lights doesn't work! (LiLaZnKiD51o)
reverse lights are for pussies anyways....oh well
Old Aug 7, 2007 | 08:51 PM
muhaMan's Avatar
i "doesnt" know whats wrong!!
Old Aug 7, 2007 | 08:57 PM
Default Re: Reverse lights doesn't work! (Tjames8864)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tjames8864 &raquo;</TD></TR><TR><TD CLASS="quote">reverse lights are for pussies anyways....oh well</TD></TR></TABLE>
wha?? Yea.. till the day you run into someone because you had no idea they had intentions on backing out.
Old Aug 7, 2007 | 09:00 PM
Syndacate's Avatar
Default Re: (sageuvagony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sageuvagony &raquo;</TD></TR><TR><TD CLASS="quote">
wha?? Yea.. till the day you run into someone because you had no idea they had intentions on backing out.</TD></TR></TABLE>
You can't pass inspection w/o reverse lights in NY.
Just how did you check it? Unplug that sensor and jump the 2 wires that connect to the sensor (not the 2 wires hanging off the sensor)</TD></TR></TABLE>
Yeah, jump the plug, the reverse lights should light up. If they do, it's a bad sensor...and I can almost guarantee that's your problem (or a bad connection to the reverse light sensor).
How'd you check it, pull it out and plug it back in? Don't exactly tell you a lot.
Old Aug 7, 2007 | 11:12 PM
Tjames8864's Avatar
Default Re: Reverse lights doesn't work! (sageuvagony)
okay people it was a joke we can all sit down now and stop flipping out lol
sense of humor...absent
Old Aug 7, 2007 | 11:13 PM
Tjames8864's Avatar
can u pass any state inspection w/o reverse lights
jw...
Old Aug 7, 2007 | 11:29 PM
phazedd's Avatar
Default Re: (Tjames8864)
u want them trust me
w/o them the ppl behind u in the other car will most likely hit u
Old Aug 8, 2007 | 12:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tjames8864 &raquo;</TD></TR><TR><TD CLASS="quote">can u pass any state inspection w/o reverse lights
jw...</TD></TR></TABLE>
Here in FL we have no inspection
Old Aug 8, 2007 | 02:37 AM
calorgan's Avatar
Its not a sensor as much as it is a switch, to check the switch itself, put the trans in reverse, get an Ohm meter, unhook the connector and read across the two wires or terminals coming off of the switch, you should have continuity between the two if you get an OL or High resistance reading replace it. If you do have continuity your problem lies in the wiring to the switch.
Old Aug 10, 2007 | 03:19 PM
thanks for the help...i did have a bad sensor so i just replaced it and it works now.
dL_EG6
17
Feb 24, 2007 09:54 PM
aserenehope
Sep 22, 2006 10:56 PM
2kTeg
Dec 14, 2005 08:34 PM
nj123
Jul 7, 2005 05:06 PM
951dc5
May 3, 2005 03:36 PM
