Fuse problem and fuel pump
From: I told you to wait in the truck in Texas, United States
Fuse #14 runs several things...
The alternator/regulator being bad or shorted is a
common cause..
Fuse #14 runs the following:
Voltage regulator
Emission control solenoid valves
PGM-FI Main relay/fuel pump
PGM-FI ECU
ELD unit
EACV
common cause..
Voltage regulator
PGM-FI ECU
ELD unit
EACV
ok thanks so if i decided to run a 15 amp fuse instead of a 10 do you think it would blow or would it be bad to put that much higher of one in there?
danmej1
Sep 28, 2010 07:20 PM
Jonny Rocket
Jul 12, 2009 09:27 PM
97civic07gsxr
15
Jan 14, 2009 06:25 PM
