WHAT IS THIS? PIC!!!
Old Aug 6, 2007 | 10:12 PM
xXSilentScreamXx's Avatar
Default WHAT IS THIS? PIC!!!
Old Aug 6, 2007 | 10:34 PM
slowman's Avatar
I took way too long
Default Re: WHAT IS THIS? PIC!!! (xXSilentScreamXx)
reverse lights.
Old Aug 6, 2007 | 10:40 PM
Default Re: WHAT IS THIS? PIC!!! (slowmanEK)
haha i guess those dont work !!! were do they go?
Old Aug 6, 2007 | 10:43 PM
slowman's Avatar
I took way too long
should be two other wires hanging around that general area the connect into them.
Old Aug 6, 2007 | 10:50 PM
sageuvagony's Avatar
When I did my auto to manual swap, the guy didn't connect my reverse lights. I was wondering what those wires were as well. I had to run the wires there from the tranny to where my old auto shifter was. Took me like 5 min.
Old Aug 6, 2007 | 10:52 PM
garyhgaryh's Avatar
ah, i had to deal with that sensor about two weeks ago. Follow the O2 sensor up to the connector that connects to the engine harness. Right above that general area of that wiring harness is a pin (right above the tranny). The connector of the sensor you circle goes there.
Also, if you remove that sensor, it's a great access hold to fill your tranny with tranny fluid. I used a liquid pump (can get on at walmart and get one for 8 bucks) to get oil in the tranny.
Gary
Old Aug 6, 2007 | 10:54 PM
Default Re: WHAT IS THIS? PIC!!! (garyhgaryh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyhgaryh &raquo;</TD></TR><TR><TD CLASS="quote">ah, i had to deal with that sensor about two weeks ago. The connector goes a set of connectors that include the connector that goes to the O2 sensor. Just find your O2 sensor and follow it up to the connector. That harness contains the connector to that sensor you circled (at least for a Civic VX).
Gary</TD></TR></TABLE>
??? I just remove the VSS and do it from there.. No pump or anything needed. Just a long funnel.
Old Aug 6, 2007 | 10:58 PM
garyhgaryh's Avatar
Default Re: WHAT IS THIS? PIC!!! (sageuvagony)
I'm sure that'll work too. I already had the sensor out so it was easy to do and it only took a few minutes . And when I was inside the tranny that hold was an obvious fill point. To each his own.
damn_import_culture
Transmission & Drivetrain
Jul 20, 2009 07:27 PM
allanonjj
Jun 11, 2005 06:29 AM
Hutch22
Nov 6, 2004 12:54 PM
HotWheelz
Jul 18, 2003 06:02 AM
