ground wires.
Old Jun 11, 2002 | 05:51 PM
Griffins_Importuning's Avatar
Default ground wires.
does any one know how many groound wires there are on a crx wiring harness. the car is not starting and is getting no spark ....i want to check all the grounds. also does anyone have any diagrams...
Old Jun 11, 2002 | 07:33 PM
spettinger's Avatar
Default Re: ground wires. (Griffins_Importuning)
the two most important grounds on the motor are from the valve cover to the frame, the trans to the frame, and the starter connections. it might also be helpful to run a ground wire from the negative terminal on the battery to the frame of the car
Old Jun 11, 2002 | 10:20 PM
r7's Avatar
r7
Default Re: ground wires. (wreckedhatch)
hm, about the valve cover to frame? wouldn't it be better from block to frame ?
because there is a valve cover gasket ? hondas come stock with valve to frame though... ?
Old Jun 11, 2002 | 10:41 PM
pg_thao's Avatar
also check the ground wire from the thermostat..
Old Jun 11, 2002 | 11:40 PM
1st-hybrid's Avatar
So if there isn't a ground wire the car won't run? Just wondering, because my swap is done, but will only crank, and not run.
After reading this, and thinking, I don't remember hooking up a ground on my starter. Where would it run from, I know the little tab on the starter, but where does it go to?
Thanks in adnvance
Old Jun 12, 2002 | 08:32 PM
Default Re: ground wires. (1st-hybrid)
same damn prob here. car did start and now it does not. what the hell. i checked and there is no spark and no fuel getting pumped...what could be the prob...ecu maybe...what is a good way to check..
Old Jun 12, 2002 | 09:46 PM
1st-hybrid's Avatar
I'm getting fuel up the the rail, but it just wont turn all the way over. I'm going to look at it this weekend, and see whats up. Maybe I'll pull everything back out and start from scratch
Old Jun 17, 2002 | 11:41 AM
SOUTHCREX's Avatar
so can anyone answer 1st-hybrid question? where dose the ground from the stater hook up at and run to? Also to clear things up a little where actually dose the one ground wire comgin from the wire harness run to. thanks
Old Jun 17, 2002 | 08:18 PM
1st-hybrid's Avatar
Default Re: ground wires. (TEAM GARAGE SHIFTDOWN)
Well I got mine running, I just made my own ground wire. I ran it from the starter, to the point where the ground is right near the clutch lever. After I did it the car turned right over . Good luck with yours, and hope that helps you.
[Modified by 1st-hybrid, 5:20 AM 6/18/2002]
Old Aug 29, 2002 | 09:43 AM
Hcivic88's Avatar
the ground wire for the starter comes out of the wiring harness, there should be a male connector on the starter and a female connector coming off of the wiring harness.
Z0831xiz
12
Aug 5, 2013 06:45 AM
ezcape
May 10, 2011 10:52 PM
chatman_55
Mar 17, 2009 08:05 PM
yeedub
Dec 10, 2006 12:53 PM
GeorgeJetson
10
Jan 16, 2004 09:54 AM
