car accident...engine won't start anymore
Old Aug 6, 2007 | 07:46 PM
Addicted 2 Adrenaline's Avatar
Default car accident...engine won't start anymore
I wrecked my car but not totaled...the passenger side air bag came on....I"m trying to start my car but it won't start...when i turn my key onto the ON position I am not able to hear the fuel pump prime....i checked all fuses already....does anyone know the problem to it?
Old Aug 6, 2007 | 07:51 PM
devney's Avatar
Default Re: car accident...engine won't start anymore (Addicted 2 Adrenaline)
does there appear to be any damage to the engine? where did your car get damaged? do you have any pics?
Old Aug 6, 2007 | 08:04 PM
andoxviii's Avatar
I know my old car (Probe GT) had a fuel cut-off switch you had to manually flip to turn the fuel system back on. I think all it did was enable/disable the fuel pump. It was located in the trunk under the carpet.
I'm not sure if Civics have those. Maybe someone with more Civic knowledge can reply regarding this matter...
Old Aug 6, 2007 | 08:07 PM
Eran's Avatar
HT White Ops
I believe (don't quote me on this) that the airbag cuts power to the fuel pump once deployed on certain model/years of civic (I believe 98+). You may have to take it to a bodyshop/dealership and have it reset.
Old Aug 6, 2007 | 08:13 PM
Default Re: (Eran)
there is no damage to the car...its a 97 hatch swapped with a b18b...the air deployed so hard that it cracked my windshield...haha...crazy...lucky there were no passenger....on damage is the right side.....headlight, bumper, and fender only...everything else is fine....
andoxviii's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">I believe (don't quote me on this) that the airbag cuts power to the fuel pump once deployed on certain model/years of civic (I believe 98+). You may have to take it to a bodyshop/dealership and have it reset. </TD></TR></TABLE>
Are you sure there isn't a way to manually do it? This is what I was talking about 3 posts up.
Old Aug 6, 2007 | 08:15 PM
gourley's Avatar
Default Re: (andoxviii)
Airbag on my friend 98 civic coupe deployed and his car started fine
Old Aug 6, 2007 | 08:42 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Double-check the No. 15 (7.5A) fuse in the underdash/relay box. They are sometimes known to blow after a front-end collision in the Civics.
Also check the Main Relay, since it is on the passenger side, under the dash on the 97.
Old Aug 6, 2007 | 08:51 PM
kjcrew_eg's Avatar
Default Re: (Eran)
You're thinking of an inertia switch. Anyone can reset them if they know the location.
Default Re: (tech8)
alright...i'll check it out
CanadianAccord1
Mar 27, 2016 11:01 PM
realistpnoy
Aug 13, 2013 08:22 PM
teg racer 877
Mar 5, 2009 05:40 PM
kuckimonster2
Jul 25, 2005 07:03 PM
DrewDown
Nov 17, 2004 12:25 PM
