del Sol won't start
Old Aug 6, 2007 | 07:40 PM
binarypunk's Avatar
New User
Default del Sol won't start
Jumper cables had no effect so I push started it with a buddy. The car runs fine and all electrical components function normally. I replaced the starter and battery, but it still will not start. I checked both inside and under-hood fuses, and visually inspected the wiring.
Next thing to check is the clutch switch, but I first have a question. I can hear the solenoid clicking when I attempt to start the car. Would it still be clicking if the clutch switch is bad?
Just trying to spare myself time spent underneath the dash. Thanks in advance!
Old Aug 6, 2007 | 08:00 PM
vsmhatched's Avatar
Default Re: del Sol won't start (binarypunk)
the clutch switch doesnt click..the sound you hearing is the the fuel pump priming, its the main relay thats clicking...have you checked your alternator, cause you said jumper cables had no effect..ubt you could push start it
Old Aug 7, 2007 | 05:25 PM
binarypunk's Avatar
New User
Default Re: del Sol won't start (GreyDel)
I just jumped the clutch switch with a paper clip and it still will not crank. Would a bad alternator really keep it from cranking? I didn't think to check it since the battery was fully charged.
magicmyst98
14
Sep 2, 2013 12:06 PM
bywaters
16
Jan 14, 2009 05:04 PM
ateggy1
Feb 17, 2008 04:58 PM
PaulHuston
Mar 18, 2007 11:16 AM
jerBEAR
Oct 31, 2005 10:34 AM
