Loud Pop when i shift????? What the hell could it be????????????/
Old Aug 6, 2007 | 05:50 PM
hondacivic90zc's Avatar
Default Loud Pop when i shift????? What the hell could it be????????????/
ok for about 3 weeks now in my 88 rex i get a loud pop sometimes when i shift mostly into 2nd and 3rd. I can usually feel it like something has hit the firewall. I did a sohc zc swap about 3 months ago and in the process replaced all of the mounts with brand new oem ebay ones so i know none of those are bad and i checked them myself. I also put in a new exedy oem clutch and throwout bearing.
I am stumped at this point what could cause this. Have any of you had a similiar problem? I was almost contemplating maybe the throwout bearing? Because when i sit still and torque the motor (sitting in one place, putting the car in gear and trying to take off with the brake on) i dont see anything hit nor do i hear the pop.
Old Aug 7, 2007 | 01:38 PM
Default Re: Loud Pop when i shift????? What the hell could it be????????????/ (iandavis90)
anybody know?
Old Aug 7, 2007 | 01:46 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iandavis90 &raquo;</TD></TR><TR><TD CLASS="quote">anybody know?
not without hearing or seeing it.
Old Aug 7, 2007 | 02:11 PM
mahatma's Avatar
shift linkage hitting exhuast?
Old Aug 7, 2007 | 02:37 PM
Default Re: Loud Pop when i shift????? What the hell could it be????????????/ (STREETWERKZ)
i am just curious if any of you had a popping sound when you shifted and was just curious what you're guys problems were.
Old Aug 7, 2007 | 04:57 PM
slow_rex_will's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iandavis90 &raquo;</TD></TR><TR><TD CLASS="quote">i am just curious if any of you had a popping sound when you shifted and was just curious what you're guys problems were.</TD></TR></TABLE>
I did, changed front motor and problem was solved, no popping!
If it's your mounts i would also suggest taking a look at this:
http://importnut.net/motormount.htm
s4yama
May 24, 2008 10:24 PM
EFB16aJP
13
Sep 14, 2005 09:04 PM
whitelightning
Aug 7, 2005 05:55 PM
Vouthanack
May 6, 2004 06:47 PM
fw190bvi
Feb 3, 2004 01:38 PM
