1990 honda civic cooling fan Problem. Need help asap!
Old Aug 6, 2007 | 05:30 PM
tigerjuice's Avatar
Default 1990 honda civic cooling fan Problem. Need help asap!
I just had a new engine swapped into my car and its getting hot and the cooling fans are not coming on. I do not have a fuse panel cover so I am not for sure which fuse is which.
Also over by the passenger headlight and airbox area there are 3 plugs but only one of them is connected to a relay.. Does anyone know what these plugs are and if they need relays? Anyone have any pictures of these connections and what they need to be plugged into?
Thanks in advance.
Old Aug 6, 2007 | 06:13 PM
Allday07's Avatar
Default Re: 1990 honda civic cooling fan Problem. Need help asap! (tigerjuice)
check #15 which is 15 amp, if that doesnt work, the relay could be bad...
Old Aug 6, 2007 | 07:48 PM
mr.speaker's Avatar
Was it working before the engine swap? if so my 1st guess is they didnt plug the fan switch back into the block..
Its a 2 prong switch in the back of the block around the oil pressure switch and oil filter area
Old Aug 6, 2007 | 08:04 PM
tigerjuice's Avatar
Default Re: 1990 honda civic cooling fan Problem. Need help asap! (Allday07)
I checked the fuse its in good shape.
I am taking a pic of the relay, can someone tell me if this looks right?
Thanks
http://www.kyhorsepower.com/levi/DSC00311.JPG
http://www.kyhorsepower.com/levi/DSC00312.JPG
http://www.kyhorsepower.com/levi/DSC00313.JPG
http://www.kyhorsepower.com/levi/DSC00314.JPG
Old Aug 6, 2007 | 08:17 PM
mr.speaker's Avatar
if you have a/c you should have 3 relay boxes..obviously you have the plugs for 3
That one in the picture and there should be 2 more by the radiator..
but if thats not the problem check that switch on the back of the block
Old Aug 6, 2007 | 08:45 PM
tigerjuice's Avatar
I checked the switch on the back of the block and its connected.
I can't find the relays for the cooling fans anywhere near the radiator...
Do you happen to have any pictures of these? Or a more specific location?
Old Aug 6, 2007 | 10:16 PM
hai_tech's Avatar
same here but i juss mak the fan run the whole time when i put the key in ignition
Old Aug 6, 2007 | 10:21 PM
My_EFsedan's Avatar
Default Re: (hai_tech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hai_tech &raquo;</TD></TR><TR><TD CLASS="quote">same here but i juss mak the fan run the whole time when i put the key in ignition </TD></TR></TABLE>
same here..once key is clicked, its on!
Old Aug 7, 2007 | 04:32 AM
mr.speaker's Avatar
That's fine for now,,but thats how fan motors burn out,not to mention what its doing to the weak stock alternator.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigerjuice &raquo;</TD></TR><TR><TD CLASS="quote">
Do you happen to have any pictures of these? Or a more specific location?</TD></TR></TABLE>
Old Aug 7, 2007 | 07:40 AM
jlicrx's Avatar
Old Aug 8, 2007 | 02:53 PM
tigerjuice's Avatar
Fixed the fan problem, cooling fan relay was bad. Installed ne one and its now fixed. Thanks guys for all the help.
Mrjgriffin
Classic Hondas
Jul 2, 2012 05:38 AM
westside49block
Feb 8, 2008 01:33 PM
boots420
Dec 23, 2007 03:22 AM
The Destroyer
10
Apr 21, 2006 01:19 PM
Linh.
Dec 24, 2005 07:11 AM
