Troubleshoot fuel pump '95 Accord
Fuel pump not getting 12v. Relay checks out good, fuses check out good. Fuel pump worked fine prior to swapping out fuel filter. Are there any safety measures Honda has built into this electrical system? (example, bad brake switch won't allow car to be placed in drive)
Black/yellow wire comes from main relay to the fuel pump, and there is a connector somewhere between the two.
Maybe a continuity test with an ohm meter?
Whiteonblackej
82
Mar 19, 2015 12:55 PM
Starpostrera
Apr 16, 2009 07:54 AM
