b16 start up problem, helpppppppp asap
Old Aug 6, 2007 | 04:15 PM
4g4db16's Avatar
Default b16 start up problem, helpppppppp asap
ok, i have a 91 civic 4dr with a b16a in it, it has a header, skunk 2 manifold, aem intake,every else is still stock, my problem is when i start my car up it idels good, idels around 850, now when i go to the store and shut it off, start it back up about 5 minutes it idels around 1500-1800 and wont go down, any ideas of what can be causing this, also the fast idel is block off with no leaks and i just replaced the iecv, any ideas will be helpfull, thanks alot
Old Aug 6, 2007 | 04:40 PM
4g4db16's Avatar
Default Re: b16 start up problem, helpppppppp asap (4g4db16)
bump up
Old Aug 6, 2007 | 05:06 PM
abnaasefmb's Avatar
let it warm up and then set the idle, also set timing. should be a good start.
Old Aug 6, 2007 | 08:57 PM
4g4db16's Avatar
Default Re: b16 start up problem, helpppppppp asap (abnaasefmb)
bumpppppppp
Corksil
13
Nov 28, 2009 07:45 PM
EF-21
May 18, 2005 04:43 PM
sicivic
Sep 23, 2002 09:28 PM
EF8_SiR
Aug 29, 2002 01:22 PM
