car boggs out while driving...
Old Aug 6, 2007 | 04:12 PM
ls19integra95's Avatar
Default car boggs out while driving...
ok so when my car is idling it sounds fine but when you go and drive it it will b fine for a minutes and then it will start bogging out and bucking around like its loosing power or miss firing... but there is no check engine light and when put in neutral it wont stall... here is the thing though... i been driving and babying it to break it in and it was fine for almost 180 miles and then all of a sudden its doin this...
the whole bottom end was just rebuilt by a shop and balanced, i tried a different dizzy and a different tps sensor, checked ground wires also... any ideas?
Old Aug 6, 2007 | 04:32 PM
Turbo-GSR1287's Avatar
Default Re: car boggs out while driving... (ls19integra95)
Check all wiring....i had a similar problem on my 94 GSR....it would drive fine for a little while then after it got hot it would start to misfire and bog out until i would shut it off and let it cool. After checking all wiring we found that after converting to external coil we used to small of a gauge wire and it ended up creating to much resistance and melting the ignition wire inside the dizzy....Also make sure your spark plugs are gapped correctly...
Old Aug 6, 2007 | 11:35 PM
Project.Jdm's Avatar
sound like what my del sol did. it would bog when i step on gas but not in nutral, but wouldnt bog if i slowing u\go up rpms and slowly on gas. it was my ignition coil and it ran perfect afther.
Old Aug 7, 2007 | 11:24 AM
Default Re: car boggs out while driving... (Project.Jdm)
all grounds are tight, i tried a dizzy thats stock... no external coil, tried different tps, checked for any bare wires, checked spark plugs and wires... all didnt work and all are ok... any other ideas... when i checked my plugs to they were completely dry but black...
Old Aug 7, 2007 | 02:26 PM
bump...
Old Aug 8, 2007 | 10:07 AM
need help...
Old Aug 8, 2007 | 10:17 AM
DA_BEATER's Avatar
try pushing the wires back in the plug for the distributer. the prongs might not be making good contact.
Old Aug 8, 2007 | 11:30 AM
dc2king's Avatar
Try the ICV (idle control valve) is it throwing any codes?
Old Aug 8, 2007 | 02:24 PM
Default Re: car boggs out while driving... (dc2king)
no codes at all
Old Aug 8, 2007 | 05:54 PM
ok figured it out, while going through things i found out my o2 sensor was shot but the problem was one of my spark plugs took a **** already not buyin them again
dakotagurule
Jan 31, 2012 06:05 AM
95blackEG
Dec 28, 2008 08:40 PM
citystars41
Jul 28, 2008 06:44 AM
hoo my gosh
May 8, 2008 05:56 PM
Coolcat55
10
May 18, 2007 07:36 PM
