Stripped Fuel Rail Nut
Old Aug 6, 2007 | 04:11 PM
Jakester9500's Avatar
Default Stripped Fuel Rail Nut
Okay, so this might not technically be model specific, but I need some advice.
I was trying to swap out my fuel injectors on my CIVIC today and found that the middle nut is too stripped to loosen it. The tool of choice is a quarter drive ratchet and 10mm socket. It worked like butter on the two end nuts, but I can' do work on that middle one.
SO...the question is, what is everyone's preferred method to remove stripped nuts, what could work in this case? Thanks in advance.
Old Aug 6, 2007 | 04:25 PM
yoffer's Avatar
Banned
You can go to Sears and get their easy out socket sets. If you go there and tell them that you have a stripped nut they'll know what your talking about. Usually no more than 30 bucks and itll work for a variety of sizes.
Old Aug 6, 2007 | 04:28 PM
t0p_sh0tta's Avatar
Default Re: (yoffer)
^ Picked up my set for $10 a while back. I'm sure that Harbor Freight tools has something even cheaper.
Old Aug 6, 2007 | 04:51 PM
ke98248's Avatar
Default Re: (t0p_sh0tta)
and get some KROIL.. It can help loosen up seized bolts/nuts..
Or if you're a cheapo, buy PB Blaster.
Old Aug 6, 2007 | 06:21 PM
Default Re: (ke98248)
I have never even heard of KROIL, everyone I run into uses PB Blaster haha.
I guess I will try one of those sockets then, I am just a little reluctant because I used one before and it didn't work, but it might have been a different kind of socket or something. Sounds like I am going to Sears! Thanks everyone.
accord_raffi
Jun 18, 2009 07:11 AM
EGk3nrock
Feb 28, 2007 09:11 PM
gunmetalcivic
Apr 17, 2006 11:55 PM
turboandbroke
May 26, 2004 08:57 AM
Judah
15
Nov 1, 2003 10:25 AM
