lowest oil pressure for vtec to work??
Old Aug 6, 2007 | 04:09 PM
blackeg's Avatar
Default lowest oil pressure for vtec to work??
just wondering if anyone knows the lowest your oil pressure can be for vtec to still work, and for your car to still run and sound right for that matter. ive been fighting with 2 different autometer oil pressure gauges and i dont think either are reading correctly. thanks
Old Aug 7, 2007 | 12:00 PM
blackeg's Avatar
Default Re: lowest oil pressure for vtec to work?? (blackeg)
up
Old Aug 7, 2007 | 06:59 PM
slowcivic2k's Avatar
Oil pressure should be 10psi minimum at idle, and 50psi at 3000rpm, so if your making 50psi at that point, it should work, according to the service manual.
Old Aug 8, 2007 | 02:56 AM
blackeg's Avatar
Default Re: lowest oil pressure for vtec to work?? (slowcivic2k)
thanks.
i had a sending unit go bad, then i had a new one in a bad spot. i just swapped it to the stock position and im making nice oil pressure
shifty35
Apr 3, 2006 12:46 PM
Islander
Jul 7, 2003 03:15 PM
MIKES
Jun 5, 2003 11:26 AM
r7
Aug 19, 2002 06:34 AM
