Calling ALL vtec specialists!! JDM H23A H2B!
Old Aug 6, 2007 | 03:28 PM
PnkRokCountryboy's Avatar
Default Calling ALL vtec specialists!! JDM H23A H2B!
******* issues..lol..
B16 Cable tranny with electronic VSS JDM H23A (motor came with a vtec head from the factory)
VTEC solenoid with out pressure switch.
P28 chipped on crome
was throwing a code, but no CEL for the pressure..but for whatever reason no longer am
thing ive done and tried, but still no luck..
-virgin P28
-different chip
-continuity between vtec pin on ecu and solenoid
-solenoid working (tested by battery) made clicking
-jumped a wire from a4 to d6 to disable the pressure (tricks the ecu)
- disabled vtec speed on crome
- Oil check/ filled even more
- Grounds..added
Im pretty sure theres more but, as of right now thats all i got
thanks guys, i need some serious help on this one
Old Aug 6, 2007 | 08:21 PM
Default Re: Calling ALL vtec specialists!! JDM H23A H2B! (PnkRokCountryboy)
yup yup
Old Aug 7, 2007 | 05:57 PM
bumpage
Old Aug 8, 2007 | 08:21 AM
TTT
Old Aug 8, 2007 | 09:57 AM
bump bump
Old Aug 8, 2007 | 07:45 PM
all motor love
Old Aug 9, 2007 | 09:50 AM
TTT
Old Aug 9, 2007 | 02:05 PM
DonF's Avatar
If you hot wire the selonoid while driving the car does VTEC work? Check the oil pressure from the head, bolt approx. 10oclock from #4 exhaust. Needs to be 60 PSI while reving the engine and VTEC engaged, around 20 PSI with vtec off. PM me.
Old Aug 9, 2007 | 04:34 PM
Default Re: Calling ALL vtec specialists!! JDM H23A H2B! (DonF)
up up
Old Aug 11, 2007 | 08:50 AM
TTT
Old Aug 11, 2007 | 09:03 AM
DonF's Avatar
So, when you drove the car and put 12 volts to the selonoid did it work?
Old Aug 11, 2007 | 06:47 PM
3timesacharm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">So, when you drove the car and put 12 volts to the selonoid did it work?</TD></TR></TABLE>
Hey DONF could it be speed sensor issue as well. I had one not working and my Vtec wouldnt work eaither computer issue I think I changed it and Vtec worked fine from there.
Old Aug 11, 2007 | 08:00 PM
Default Re: Calling ALL vtec specialists!! JDM H23A H2B! (3timesacharm)
well my VSS is working according to my m.p.h and im not throwing any codes for it..but do you think i should still try a different one?
Old Aug 11, 2007 | 10:51 PM
JDM_COUPE's Avatar
PMed
Old Aug 12, 2007 | 11:55 AM
Default Re: Calling ALL vtec specialists!! JDM H23A H2B! (JDM_COUPE)
bumppp
Old Aug 12, 2007 | 01:01 PM
DonF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnkRokCountryboy &raquo;</TD></TR><TR><TD CLASS="quote">bumppp</TD></TR></TABLE> Doh? Does VTEC work when you hot wire it while driving? Is this to hard to do? A wire and switch? If you cannot do this, take it to a dealer. Did you do all the Helm's tests?
Old Aug 12, 2007 | 09:18 PM
yes, i did the helms tests..thats why i have came upw.no electrical issues.
i'm off work tomorrow so im gonna try it.
i bumped it to see if anyone had any other responses before i test on this **** all day..and most likely will end up w. no answers again, k thanks
Old Aug 13, 2007 | 09:37 PM
hardwired the solenoid and vtec does work...whats next guys!? need to get this car running right!
Old Aug 13, 2007 | 09:51 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Try a diff solenoid?? Stupid but it worked for me once,when all else failed...
Old Aug 14, 2007 | 08:39 AM
Default Re: Calling ALL vtec specialists!! JDM H23A H2B! (cb7-R)
TTT
Old Aug 14, 2007 | 04:25 PM
up up
Old Aug 14, 2007 | 08:02 PM
Chris Tune's Avatar
do you have vtec pressure switch?... if you dont it will never ever activate unless u disable it on crome and then ground it...
Old Aug 15, 2007 | 09:36 AM
Default Re: Calling ALL vtec specialists!! JDM H23A H2B! (Chris Tune)
no pressure switch.. jdm selonoid.
i tried to jump A4 to D6 to disable it and it didnt make a difference
Old Aug 16, 2007 | 08:56 AM
shiiiiittt help?
Old Aug 17, 2007 | 01:09 PM
up up
