Is stock LS oil pump good enough for LS vtec? Or b16?
Old Aug 6, 2007 | 02:35 PM
boredracer408's Avatar
Default Is stock LS oil pump good enough for LS vtec? Or b16?
Do i need to swap out the stock LS oil pump when doing an LS VTEC for a b16 one?
THanks!!
Old Aug 6, 2007 | 03:20 PM
ekBlackHatch's Avatar
Default Re: Is stock LS oil pump good enough for LS vtec? Or b16? (boredracer408)
you should get a new one either or when rebuilding
Old Aug 6, 2007 | 03:24 PM
MDM's Avatar
MDM
Default Re: Is stock LS oil pump good enough for LS vtec? Or b16? (ekBlackHatch)
get a type R oil and water pump
u dont have to, i think b16 does it!
Old Aug 6, 2007 | 03:30 PM
95ProjectEJ1's Avatar
Default Re: Is stock LS oil pump good enough for LS vtec? Or b16? (MDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MDM &raquo;</TD></TR><TR><TD CLASS="quote">get a type R oil and water pump
u dont have to, i think b16 does it! </TD></TR></TABLE>
Type-R FTW... a little pricey if you are going with new OEM parts instead of used.
Old Aug 6, 2007 | 03:32 PM
MDM's Avatar
MDM
Default Re: Is stock LS oil pump good enough for LS vtec? Or b16? (95ProjectEJ1)
^^ tell me about it!!
Old Aug 7, 2007 | 04:01 PM
doood's Avatar
been there done that
so everyone knows, ALL 96+ b series oil pumps are identical. all 96+ b series vtec water pumps are identical. just because it's type r doesnt make it special.
Old Aug 7, 2007 | 04:32 PM
Default Re: Is stock LS oil pump good enough for LS vtec? Or b16? (doood)
lmao what this guy said they are all the same its going to run you about 100$ for the oil pump i think the water pump is about the same if you want a place to orderfrom i know a repbl one just send me a pm they ship real fast 2
bOOsT-FeIn
Aug 16, 2006 08:28 PM
BeeEK9R
Jul 7, 2006 10:47 PM
b16vtecsol
Nov 14, 2003 05:34 PM
X2BOARD
Apr 10, 2002 01:49 PM
