Changed Alternator and Battery Twice, Car still dies!!! No Recharge? HELP
Old Aug 6, 2007 | 12:34 PM
fms1day's Avatar
Default Changed Alternator and Battery Twice, Car still dies!!! No Recharge? HELP
Alright, I'm posting this for a friend here. He can't figure out what's wrong with it so I figured I'd help him turn to the gurus of H-T for some answers.
My friend's 94 Honda Civic Coupe recently died on him while driving. He tried to start it up again and it wouldn't. Initially he thought it was the battery, so he replaced it..... Twice. And each time, the problem still happened. It ran and then died. SO now he turned to the alternator and had that replaced.... Twice. Still the problem exist!!! He doesn't know what it could be anymore. So I'd like to ask the H-T community for some possible answers.
Side Note: He recently installed foglights but didn't do it the "traditional" way in wiring, and just hooked it up directly with the parking light wiring so that it would turn on with the first click of the headlight switch.
Not sure if this has any possible effect on his main problem but I thought I'd put it out there.
THanks in Advance!
Old Aug 7, 2007 | 05:03 PM
JDM-TIM's Avatar
Default Re: Changed Alternator and Battery Twice, Car still dies!!! No Recharge? HELP (fms1day)
wow i got the same problem! and i conected the fogs wrong myself.. im changing the alternator tomorrow, i got a 96ek
Old Aug 7, 2007 | 05:20 PM
JSPECSIR's Avatar
Default Re: Changed Alternator and Battery Twice, Car still dies!!! No Recharge? HELP (JDM-TIM)
did you check the main fuse in the under hood fuse box?
Old Aug 7, 2007 | 05:26 PM
gsxr1k05's Avatar
if the fog lights are not on when they parking lights are not on, that should not be causing it. but it this started AFTER he hooked up the lights, then i would look to them as the source of the drain. check the battery cables just for sake of mind and see if they are corroded at all. but if he is going to keep the fog lights hooked up to the main light switch, he should use a relay. they help prevent **** like this from happening
Old Aug 7, 2007 | 05:28 PM
suspendedHatch's Avatar
Default Re: (gsxr1k05)
Make sure the thick white wires in the fuse box and the power wire at the starter are tightened down all the way.
You shouldn't replace a battery or alternator w/out first testing them. Alternator can be checked in 5 seconds using a $15 multimeter. Battery can be checked for free at Kragen or Autzone.
Old Aug 15, 2007 | 09:40 PM
fms1day's Avatar
Default Re: (suspendedHatch)
Friend found the problem.
One loose wire in the engine bay fuse box.
Another loose wire/plug else where.
thanks all.
ej2man
Jan 13, 2009 08:58 AM
dc2_fanatic
Dec 25, 2006 08:57 PM
Eucalyptus lude
May 22, 2005 07:16 PM
ID_ten_T
Nov 2, 2004 11:24 PM
crawdad689
Nov 21, 2003 11:35 PM
