What offset wheels for drag slicks?
Old Aug 6, 2007 | 10:13 AM
JKov240's Avatar
Default What offset wheels for drag slicks?
I just came across a set of drag slicks that my cousin had borrowed from my brother a while back that was used on his 1G DSM. I do believe that they're 22x8 slicks...but I'm not sure what offset wheel to use. Any suggestions?
Old Aug 8, 2007 | 07:53 AM
JKov240's Avatar
Default Re: What offset wheels for drag slicks? (JKov240)
bump for an answer
Old Aug 8, 2007 | 08:05 AM
Innes's Avatar
what model car and what brakes?
Old Aug 8, 2007 | 08:40 AM
JKov240's Avatar
Default Re: What offset wheels for drag slicks? (Innes)
'94 Honda Civic DX hatchback...stock brakes.
Lowered on Tokico Illumina Adjustables with Eibach Sportline springs (about 1.5" of wheel gap in the front)
Old Aug 8, 2007 | 08:59 AM
Innes's Avatar
4" or 5" backspacing will work best
5" will bring the wheel further into the wheel well
4" will push it out a bit more
personally i like the 5" option -- most of the time and most setup's don't have to run spacers on stock civic brakes -- you will have to run a spacer with a gsr brake setup
Old Aug 8, 2007 | 09:27 AM
JKov240's Avatar
What about the offset on the wheel? I think the stock wheels (and the ones I currently have on my car) are around a +42 offset.
Old Aug 8, 2007 | 10:36 AM
A.E Motoring's Avatar
some drag wheels dont go by offsets, they go by back spacing, only ones i know of that go by offset, are lensos, those are +15 i believe, others like welds, bogart, etc etc go by back spacing, since your using stock brakes u can just get some lensos, or a wheel with a 4 inch back spacing
Old Aug 8, 2007 | 10:49 AM
ExospeedAMcrx's Avatar
Default Re: What offset wheels for drag slicks? (Dual Cam Racing)
the Exospeed VPD 13x7.5, formerly known as Lenso, are +25 offset. which comes out to about 4.5" backspace
Old Aug 8, 2007 | 01:11 PM
JKov240's Avatar
Default Re: What offset wheels for drag slicks? (exospeedAMcrx)
Anybody know of a 15x8 race wheel?
I've looked at the Lensos (which look clean by the way) and only see them in a 13x7.5
EDIT: Scratch that, I found some Welds
Modified by JKov240 at 2:55 PM 8/8/2007
rudebwoy
Apr 11, 2010 12:46 PM
boostek9
May 9, 2008 07:21 PM
Huee
Aug 25, 2004 07:21 PM
Pinhead
Apr 11, 2002 03:53 PM
