WHAT CAN HAPPEN IF..(GE HEAD STUD QUESTION)
From: Ontario,where cops smash ur cars and make you watc, CA, US OF A
What can happen if you don't re torque your new ge head studs?? I searched and found nothing...
I've been debating pulling the cams to retorque the bolts on my build too.
With the heating and cooling cycles it allows everything to expand and contract a bit. There is probably stress relieving going on as well hence the need to retorque the studs. I will try it, maybe if you do too post your results on if the torque changed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma »</TD></TR><TR><TD CLASS="quote">you could blow your headgasket.
i'm about 600 miles into a fresh rebuild and i'm fighting my laziness to do this too</TD></TR></TABLE>
Post your results when you re-torque. Did the nuts move?
