Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
**yOdeals Daily Blowout Special .. Woot.com! for Performance Parts**
Old Aug 6, 2007 | 09:06 AM
tom@yoparts.com's Avatar
Default **yOdeals Weekly Blowout Specials ****
yOparts.com is excited to be Official thread Sponsor of the Drag Race forum here on H-T.....
Deal ends as soon as we run out.. this is a sample of what yOparts Members get access to all the time
E-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system without changing the entire factory ECU system to a "stand-alone" unit. The E-Manage system is a "poggy-back" type unit that will save you from wiring headaches by working in conjunction with factory ECU. This system will allow the tuner to easily control the pulse duration of factory injectors or upgraded injectors with a built in adjustable dial, It also has a built-in VTEC controller which can adjust the VTEC shift point as well as the fuel curve. An optional communication software package (PC Windows) and harness kit is available to fine tune the entire engine, from 16 additional fuel RPM points, ignition timing, larger injectors, airflow meters, injector duty cycle, and control up to 2 sub injectors, with the use of optional communication software and a PC Window based lap-top, the E-manage system will assist the tuner in data logging and real time monitoring capability.
PRICE 289.99 Shipped
Go here to take a look this has an RSS feed as well so you can subscribe and get parts at cost
Modified by tom@yoparts.com at 10:28 AM 8/7/2007
Old Aug 7, 2007 | 05:55 AM
Default Re: **yOdeals Daily Blowout Special .. Woot.com! for Performance Parts** (tom@yoparts.com)
ttt
grizzy225
Apr 11, 2007 04:26 AM
JunIntegra
Oct 10, 2004 10:04 AM
onelowchef
May 29, 2004 04:23 AM
tbisme
Jan 3, 2003 07:43 AM
