high compression/ wideband
Old Aug 6, 2007 | 07:54 AM
MelloYelloCRX's Avatar
Default high compression/ wideband
running a high compression application 11-6-1 wideband settings that i have found say 14.7 seems a little lean to me.... should i try richening it up just a little?
Old Aug 6, 2007 | 08:45 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: high compression/ wideband (MelloYelloCRX)
Do you trust your wide band or no?
It says it's 14.7 that's stoch for a gas motor. That means, not rich, not lean. I fail to see what you are really asking.
Old Aug 6, 2007 | 11:08 AM
91r-e-xsi's Avatar
14.7 is perfect when you are at idle or cruizing. What is the a/f reading when at w.o.t???
Old Aug 6, 2007 | 12:30 PM
Default Re: high compression/ wideband (91r-e-xsi)
not stock motor, high compression... reason im asking im using the d16y8 intake manifold, so it idles kind of erractic, also it is throwing code 1 which is o2 sensor, i am not using stock o2 bypassed it and wired wideband o2 to my stock wire harness.....
Old Aug 6, 2007 | 02:38 PM
danmdevries's Avatar
What does a Y8 IM have to do with your idle other than its probably the source of a vacuum leak somewheres?
Old Aug 6, 2007 | 04:03 PM
abnaasefmb's Avatar
Default Re: high compression/ wideband (danmdevries)
wow, you have an ecu that supports wideband input?
Old Aug 6, 2007 | 06:25 PM
Default Re: high compression/ wideband (abnaasefmb)
guy at local tune shop said to just bypass stock o2 an wire in wideband o2 in its place
Old Aug 6, 2007 | 07:03 PM
abnaasefmb's Avatar
Sounds like he didn’t explain himself well. Some widebands have a narrow band out put and you could use that. Some rom editors allow you to disable the o2 sensor and some well one let you run closed loop with a wideband. If you have a stock ecu and unplug the o2 bad thing will happen.
Old Aug 6, 2007 | 07:11 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MelloYelloCRX &raquo;</TD></TR><TR><TD CLASS="quote">guy at local tune shop said to just bypass stock o2 an wire in wideband o2 in its place</TD></TR></TABLE>
He meant to get a chipped ECU that is capable of being tuned with a wideband 02 sensor. Your ECU is probably wondering what the **** is going on.
Get it chipped before it becomes unhappy with it's home life and starts seeing other people.
Old Aug 8, 2007 | 10:13 AM
lowest value is 7.40 highest is ---..... but while idling it will flash e 2 and then sometimes heating up o2 screen.... not sure what to do now.... idles at 14.5 to 15.6 o2 code is gone though so that is a plus...lol
Old Aug 8, 2007 | 12:05 PM
abnaasefmb's Avatar
what?
Old Aug 8, 2007 | 04:47 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">what?</TD></TR></TABLE>
x2.
Old Aug 8, 2007 | 05:50 PM
Default Re: high compression/ wideband (Tippyman)
got o2 hooked up as follows off the LC-1..... red to power, green, blue an white to ground, yellow to ecu harness (o2) under the hood, brown to green wire from xd-16 gauge, black wire taped off.... while car is idling the gauge flashes e 2, then somtimes will go through o2 heating up cycle..... just not sure how to fix this
Old Aug 8, 2007 | 06:35 PM
Tippyman's Avatar
Black wire is a ground wire. It needs to be treated as such, not just taped off.
Old Aug 11, 2007 | 12:30 PM
well if i read the online manual it said black is calibration wire? car runs fine till i let off gas while driving numbers jus go crazy then i get the o2 display, push back on gas an its back to normal.....
Old Aug 11, 2007 | 01:16 PM
my neighbor suggested running my stock o2 sensor, an putting wideband o2 down further on my headers
bigmikey7351
Jun 3, 2008 09:01 PM
jerseydevil
Dec 10, 2003 03:31 AM
kwiker
Dec 7, 2003 10:26 PM
Jared
Nov 15, 2001 06:08 PM
