What should I do next? b16a2 ideas
Old Aug 6, 2007 | 12:13 AM
HCivicSi23's Avatar
Default What should I do next? b16a2 ideas
Hey guys... well I have a 99 civic si with it's original b16a2 in it. I picked it up a while back for about 6,500 with 123,000 miles on it. It has no signs of abuse in anyways and runs pretty good minus a few problems here and there.
I originally bought the car for a daily driver, but project car as well. I have made a few improvements to the car such as the intake, exhaust, suspension, and the clutch and flywheel. Other than that, the car is all bone stock. I have a tight budget and aam struggling over what I should do with the car from here on out. I want to build the motor and turbo the car eventually... I am not out for mad speed and would probably run 8 pounds of boost into the car max... just a lightweight turbo so I don't cause to much wear on the car.
I don't have a deep wallet and would like to hear what you guys think I should do from here...
Old Aug 6, 2007 | 12:30 AM
RollinEk's Avatar
If you go turbo, dont think that you are out the price of the kit and your done. There is a lot of upkeep when going turbo. Plus, you got some decent mileage on the car, not the best time to be boosting IMO. Id do some interior work and make it all nice inside.
Old Aug 6, 2007 | 12:33 AM
HCivicSi23's Avatar
Default Re: (RollinEk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RollinEk &raquo;</TD></TR><TR><TD CLASS="quote">If you go turbo, dont think that you are out the price of the kit and your done. There is a lot of upkeep when going turbo. Plus, you got some decent mileage on the car, not the best time to be boosting IMO. Id do some interior work and make it all nice inside.</TD></TR></TABLE>
The car could be turbocharged as it is now if I really wanted to, however I would rebuild the motor and switch up the compretion ratio if I actually do put a turbo on the car. The interior as it stands now is very nice, I haven't changed anything in there. The only thing I would really want to change there is the seats.
Old Aug 6, 2007 | 01:57 AM
MatterMatt's Avatar
Default Re: What should I do next? b16a2 ideas (HCivicSi23)
Save your $ and start building your motor for turbo. Yank that motor out and have your mom drive you to school while you build it up.
Old Aug 6, 2007 | 05:19 AM
cmasonrun's Avatar
Default Re: What should I do next? b16a2 ideas (MatterMatt)
get more displacement.....
Old Aug 6, 2007 | 05:29 AM
speedooo's Avatar
Default Re: What should I do next? b16a2 ideas (cmasonrun)
i vote for upping the displacement
Old Aug 6, 2007 | 05:33 AM
HXvtec's Avatar
you dont have a deep wallet? hmmm. here my advice. dont do anything. save your money. you have I/E. the car sounds nice. leave it alone till you can save up money.
2000siturboR's Avatar
well if i was in your situation i would either go with jackson racing suer charger or greddy turbo kit depends how much you want to spend. i have a built 2000 civic si with greddy turbo kit running 7 psi i like it an all its just a hassle cause then ya go buy **** like guages turbo timers stupid **** so you dont blow it up thats i should have went with a jackson racing suppercharger sure its not as fast but better for the motor in the long run would have to build it and prolly would have sounded nicer my advice to you is look into a jackson racing super charger its prolly gona run you about 4 or so but you wont need to build it considereing they only run about 5 psi
Old Aug 6, 2007 | 05:40 AM
HXvtec's Avatar
Default Re: What should I do next? b16a2 ideas (2000siturboR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000siturboR &raquo;</TD></TR><TR><TD CLASS="quote">well if i was in your situation i would either go with jackson racing suer charger or greddy turbo kit depends how much you want to spend. i have a built 2000 civic si with greddy turbo kit running 7 psi i like it an all its just a hassle cause then ya go buy **** like guages turbo timers stupid **** so you dont blow it up thats i should have went with a jackson racing suppercharger sure its not as fast but better for the motor in the long run would have to build it and prolly would have sounded nicer my advice to you is look into a jackson racing super charger its prolly gona run you about 4 or so but you wont need to build it considereing they only run about 5 psi </TD></TR></TABLE>
do you not believe in periods?
Old Aug 6, 2007 | 07:30 AM
5_Lug_B's Avatar
* B A N N E D *
Default Re: What should I do next? b16a2 ideas (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">
do you not believe in periods? </TD></TR></TABLE>
Lol. Keep it the way it is until you have enough to do what youd like to do to the car.
Old Aug 6, 2007 | 09:14 AM
HCivicSi23's Avatar
I wont supercharge the car, I would only turbo it. I plan on building my motor first over anything. What should the compression ratio be? I thought about keeping it the same so I can drive the car around and if I do decide to go turbo... I will. The stock compression isn't bad for running 5-8 pounds of boost.
Old Aug 6, 2007 | 09:27 AM
Kelb's Avatar
i say that for now, worry bout your internals. Get new cams, cam gears, pistons, rods, rod bolts, crank shaft, port and polish the head, 3 angle valve job, bigger fuel pump, have some fun. N/A is sexy.
Old Aug 6, 2007 | 09:47 AM
95ProjectEJ1's Avatar
Default Re: (Kelb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kelb &raquo;</TD></TR><TR><TD CLASS="quote">i say that for now, worry bout your internals. Get new cams, cam gears, pistons, rods, rod bolts, crank shaft, port and polish the head, 3 angle valve job, bigger fuel pump, have some fun. N/A is sexy.</TD></TR></TABLE>
After ...
Cams - $300+
Gears - $180+
Pistons - $500
Rods - $350
Head studs/Main bolts - $150+
Polish/Balance crank - $150+
P&P with valve job and larger valves- $1k
Fuel pump - $150+
you are at $2500+ (parts w/ partial labor ie crank/p&p) , making less whp then you would have going turbo for the same price and you now have a lopey idle and less mpg for your DD. N/A is great and all, but not for a DD.
Old Aug 6, 2007 | 10:03 AM
HCivicSi23's Avatar
Default Re: (95ProjectEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
After ...
Cams - $300+
Gears - $180+
Pistons - $500
Rods - $350
Fuel pump - $150+
you are at $2500+ (parts w/ partial labor ie crank/p&p) , making less whp then you would have going turbo for the same price and you now have a lopey idle and less mpg for your DD. N/A is great and all, but not for a DD. </TD></TR></TABLE>
Yea. The car is still a daily driver. I would rebuild the motor to factory spec which would be cheeper then buying all performance aftermarket parts etc. Then, if I decide to go turbo, it can be done.
Old Aug 6, 2007 | 11:27 AM
.PLUMMM's Avatar
you have a pretty nice DD setup already. if your looking for something a bit more, you could put some cams in (CTR possibly = ]), some valve springs and retainers, and then just have fun with the interrior! but without boost or building the motor you have a decent daily already. Good luck on deciding something!
Old Aug 6, 2007 | 11:38 AM
stock99si's Avatar
u dont have to build up ur engine to run 8 psi in most cases.
Old Aug 6, 2007 | 12:04 PM
hackykid's Avatar
Default Re: What should I do next? b16a2 ideas (stock99si)
There is a guy running 14lbs on a .57 trim with 350+ whp, stock b16a2. If u dont have the money, dont bother, u will end up with half the parts and realize it wasnt worth it. Stick to looks, thats my opinion.
Old Aug 6, 2007 | 12:47 PM
Archidictus's Avatar
Unceasing Measure
Default Re: What should I do next? b16a2 ideas (hackykid)
The advice in this thread is among the worst I've ever seen
1.) if you're "on a tight budget" don't worry about how fast your car is until you've made it out of that period in your financial journey.
2.) if you want to make your B16 faster, boost is the only reasonable option.
3.) if you want to run 8 pounds and make 250 at the wheels you don't need to do anything to your engine at all. Get a treadstone turbo kit for $1700, find a BOV you like and pay $400 for tuning. Bam. 13's all day on street tires.
You need to do more searching and less talking to the noobs. Everybody has opinions, but few people have the experience necessary to give you GOOD advice.
Old Aug 6, 2007 | 02:50 PM
HCivicSi23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si &raquo;</TD></TR><TR><TD CLASS="quote">u dont have to build up ur engine to run 8 psi in most cases.</TD></TR></TABLE>
Which is why I would rebuild the motor to factory specifications. I can get away with re honing the cylinders, topping the deck... hot tanking the block and possibly replacing the pistons and connecting rods with an aftermarket factory spec option. The only difference would be the durability. Then I would put a lightwieght turbo on the car.
Does any one know of any good turbo systems under like 3k?
HCivicSi23's Avatar
Default Re: What should I do next? b16a2 ideas (Archidictus)
You need to do more searching and less talking to the noobs. Everybody has opinions, but few people have the experience necessary to give you GOOD advice.[/QUOTE]
Is the treadstone turbo reliable?
Old Aug 6, 2007 | 05:21 PM
l2edken's Avatar
add stickers... they add 20 HP minimum...
Old Aug 6, 2007 | 05:31 PM
Default Re: What should I do next? b16a2 ideas (l2edken)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l2edken &raquo;</TD></TR><TR><TD CLASS="quote">add stickers... they add 20 HP minimum...</TD></TR></TABLE>
^^ someone had to meet quota for the day...
Old Aug 7, 2007 | 11:21 PM
HCivicSi23's Avatar
Default Re: What should I do next? b16a2 ideas (95ProjectEJ1)
Bump.
Old Aug 7, 2007 | 11:33 PM
BigDeal's Avatar
HomeMadeTurbo TIME. take it easy on the car and start collecting the needed essential and then by the time all is together you'll be ready to boost. Thats what im doing.
Old Aug 11, 2007 | 12:17 AM
HCivicSi23's Avatar
Default Re: (BigDeal)
Bump.
924doorEG
Feb 24, 2008 06:26 PM
vtecgod
Aug 19, 2007 06:54 AM
EM199dcs
Jan 10, 2006 03:57 PM
