b16 electronic vss sir cluster problem HELP PLEASE
Old Aug 6, 2007 | 12:01 AM
civichatch2307's Avatar
Default b16 electronic vss sir cluster problem HELP PLEASE
hi i have a 90 civic si with a b16 with a y1 trany witch has a electronic vss after i wired it all up the speedo works fine on the cluster but my engine light is still on and i was wondering if either the sensor is shot or if i might of wired it wrong originaly i had it just going to ground power and to the cluster but then i read that i had to spice the wire going to the cluster and splice to the speed sensor wire going to the ecu with i beleive is plug B #16 after i did that my engine light is still on so im thinking my sensor is shot any help would be awsome thanks
Old Aug 6, 2007 | 04:18 AM
VegaS10's Avatar
Punctuation is your friend.
Do all the gauges work?
What code is being thrown?
How long has all this been in the car?
Old Aug 6, 2007 | 11:19 AM
Default Re: (VegaS10)
yes all my gauges work fine but its spiting code 17 vss its been i my car for about a month and a half now
Old Aug 6, 2007 | 02:54 PM
VegaS10's Avatar
You need to run the vss signal wire to your ecu. Your factory gauge cluster used to send that signal to the ECU, your new one does not, hence the code 17.
Don't forget to reset your ecu one you run the vss wire.
Old Aug 6, 2007 | 05:17 PM
ill try that tomorow to clear the engine code id just disconect the batterie for like 20min right
Old Aug 7, 2007 | 03:06 AM
VegaS10's Avatar
It only takes about 2-3 minutes to reset, but 20 will work.
Old Aug 7, 2007 | 07:06 PM
problem solved thanks so much VTEC roars
FakeJDMEF8
Nov 7, 2004 07:22 PM
schwanginpt
Jun 28, 2004 08:05 PM
EF-21
Mar 15, 2004 04:51 PM
EF_LSVtec
Oct 29, 2002 01:36 PM
QWKPHKR
Dec 24, 2001 04:22 PM
