painting front bumper! help....
Old Aug 5, 2007 | 10:08 PM
jorge59la's Avatar
Default painting front bumper! help....
i want to paint my front bumper of my car. i have no idea where to buy the paint or sandpaper. Any help? thanks
Old Aug 5, 2007 | 10:13 PM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Re: painting front bumper! help.... (jorge59la)
NICE , like how the corners and wheels work together, a paint shop SHOULD have it, if not, they suck...
Old Aug 5, 2007 | 10:16 PM
slomob18b's Avatar
Default Re: painting front bumper! help.... (Project95LS-VTEC)
Damage doesn't look too bad, but maybe you can try http://www.paintscratch.com.
Old Aug 5, 2007 | 10:35 PM
bg-33p's Avatar
Default Re: painting front bumper! help.... (slomob18b)
Go to any car part store like autozone for sand paper, then you can either go to your local paint store and ask them mix a can of your car code color or <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomob18b &raquo;</TD></TR><TR><TD CLASS="quote">Damage doesn't look too bad, but maybe you can try http://www.paintscratch.com.</TD></TR></TABLE>
Old Aug 6, 2007 | 03:45 AM
ironlung78's Avatar
save the money and have it done right. its never going to match and will probably look worse!
Old Aug 6, 2007 | 05:04 AM
g0tgot's Avatar
ok start off with some 80 grit and sand down the WHOLE AREA OR PEICE BEING SANDED.....use some putty/bondo to get any defects that might keep the peice from looking great after paint......then sand with 120 and putty one more time just to be safe......sand with 120 again then primer, then sand with 400/ base coat/ then sand with 1000 and then clear coat/ then sand with 1200 and clear coat again// then buff if needed.......if you get orange peel or any sort of clouding then start by sanding with 400 again and start with the basecoat......good luck!
Old Aug 6, 2007 | 05:05 AM
g0tgot's Avatar
o btw since its the front bumper.....you might have to do this to the fendors as well for a blending act......go from top to bottom light (top) to dark (bottom) like a shading effect so that you dont see 2 diff paint colors......new paint is diff than old paint....less mettals and sheat.....
Old Aug 6, 2007 | 06:20 AM
B18 Piston's Avatar
even like that looks good
Old Aug 6, 2007 | 09:17 AM
TruGsr1's Avatar
Default Re: (TYPERRER)
just get a itr lip and paint that. It will cover most of the scratches
Old Aug 6, 2007 | 09:20 AM
B18 Piston's Avatar
Default Re: (TruGsr1)
yea
Civic98Cali
Paint and Body
Oct 18, 2013 03:30 PM
KangBanger
Paint and Body
Apr 17, 2008 06:33 PM
burnitdown
Paint and Body
Jul 12, 2007 01:37 PM
flybert
Nov 17, 2004 06:49 PM
Dspad_91Civic
Apr 21, 2004 10:38 AM
