Oil leak from head.
Old Aug 5, 2007 | 08:13 PM
grizzy225's Avatar
Default Oil leak from head.
Had a head gasket issue back in the day car got pretty hot... First time i had a shop do it for me.. used the old head studs and it leaked dumb idea. The leak started from the dizzy pretty good then the whole **** just puked oil. Second time i redid the headgasket i bought ARP head studs and did the job myself. Had the head machined this time and used the headstuds. Anways, i still have minor leak coming from the corner of the head under the dizzy... think the block somehow warped? not sure how that would happend from a little heat.. i've seen worse. Any ideas?
(JDM B16A-no major motor work)
thanks for the help
Old Aug 5, 2007 | 08:19 PM
slowcivic2k's Avatar
Default Re: Oil leak from head. (grizzy225)
Check the distributor for oil leaks, that o ring gets hard and leaks all over the bellhousing. Also check inside the cap and in the dizzy for oil, as there is a seal in there as well that is prone to leaking.
Old Aug 5, 2007 | 08:20 PM
grizzy225's Avatar
Will check that out 2marro.. thanks any other opinions?
Old Aug 6, 2007 | 07:48 AM
92_civic's Avatar
Default Re: (grizzy225)
check the cam seal as well
Nick Azzarto
Jun 22, 2014 08:10 PM
jlopez88
May 14, 2008 07:23 PM
tegdude227
Jul 22, 2007 10:36 AM
SLVRSTN_DC4
Jul 26, 2005 03:47 PM
Nextelbuddy
May 5, 2003 08:10 PM
