nuetral safety switch
Old Aug 5, 2007 | 07:39 PM
95lscivic's Avatar
Default nuetral safety switch
on my way home from a friends house tonight i got in my car and turned it on. it is a b16a swapped crx si. i went to get something to drink at a gas station. came back out put tried to turn the car on. nothing. no coes, fuel was priming blah blah blah. it's not spark. i pushed started the car so it's not ignition either. im thinking that the nuetral safety switch came unplugged or shorted somehow. any other suggestions? thanks in advance.
(is the safety switch located on the clutch pedal or on the transmission?)
Old Aug 5, 2007 | 07:50 PM
keganaraujo's Avatar
Default Re: nuetral safety switch (95lscivic)
top of the clutch pedal assembly. i believe its a yellow plug.
Old Aug 5, 2007 | 09:31 PM
95lscivic's Avatar
Default Re: nuetral safety switch (keganaraujo)
ttt. does that sound like a good assumption? it's to dark to see anything right now.
Old Aug 5, 2007 | 09:38 PM
BIG_T's Avatar
do u have a aftermarket alarm? my last car did the same thing and the alarm was shorting everything out. the sns sounds like a possibility
Old Aug 5, 2007 | 10:05 PM
95lscivic's Avatar
Default Re: nuetral safety switch (BIG_T)
no aftermarket alarm.
Old Aug 6, 2007 | 01:49 PM
iheartteal's Avatar
my buddies crx did that, try to reach up there and push the switch in and get some to try and start it for you, but make sure its out of gear
ej6KRON
11
Aug 2, 2009 11:04 AM
Odessa
Audio / Security / Video
Aug 18, 2004 07:37 AM
photonjedi808
30
Mar 28, 2003 09:58 AM
GreenD
Sep 15, 2002 02:22 PM
