cluster/climate control/tailight went out
Old Aug 5, 2007 | 07:09 PM
trick_db's Avatar
Default cluster/climate control/tailight went out
never mind. got it
Modified by trick_db at 9:53 PM 8/5/2007
Old Aug 5, 2007 | 07:19 PM
trick_db's Avatar
Default Re: cluster/climate control/tailight went out (trick_db)
bump
Old Aug 5, 2007 | 07:25 PM
gmv's Avatar
gmv
should just be a 10amp fuse under your dash that has blown for some reason
Old Aug 5, 2007 | 07:28 PM
trick_db's Avatar
Default Re: cluster/climate control/tailight went out (gmv)
yea i know, but doesnt know what fuse.. so many..
Old Aug 5, 2007 | 07:40 PM
trick_db's Avatar
someone gotta noe
Old Aug 5, 2007 | 07:50 PM
slomob18b's Avatar
Happened to me before when I had my Integra. I just checked every fuse under the dash. I think there are about 20-30 of them I forget. I'll see if I can find it in the Helms and I'll let you know.
Old Aug 5, 2007 | 07:51 PM
trick_db's Avatar
Default Re: cluster/climate control/tailight went out (slomob18b)
i used to have a 96 integra and i know what fuse, just recently bought another integra, 98 and its different.
Old Aug 5, 2007 | 07:54 PM
slomob18b's Avatar
From my 1998 Integra Helms it can either be:
Fuse Number Amps Wire Color Description
25 7.5 Yel/Blu Clock, gauge indicator lights
30 7.5 Red/Blk Dash lights, clock
32 10 Red/Blk Front parking lights, taillights...
Check those and let me know if they are not one of them.
Old Aug 5, 2007 | 07:57 PM
trick_db's Avatar
ima check it right now.
Old Aug 5, 2007 | 08:08 PM
trick_db's Avatar
25, 20, and 32 checked and its still good. any more?
Old Aug 5, 2007 | 08:36 PM
trick_db's Avatar
up?
Old Aug 5, 2007 | 08:58 PM
slomob18b's Avatar
Turned out to be fuse 52 under the hood if anybody else has this issue.
Old Aug 5, 2007 | 09:03 PM
trick_db's Avatar
thanks for all the help.
vtecstacy21
Nov 16, 2007 11:05 AM
GJWilliamson
Jul 11, 2007 03:55 PM
futurefastguy
Sep 8, 2006 06:31 AM
O16581724 5 2 5
Mar 3, 2006 12:43 AM
