need help, couldn't find a write up on this.
Old Aug 5, 2007 | 05:14 PM
teg-96's Avatar
Default need help, couldn't find a write up on this.
I have a 96 ls integra, and when i'm stopped (at a light), and i have my car in 1st gear and the clutch depressed, my car jumps. SOMETIMES. it doesn't do it all the time. I was wondering if anyone has any ideas on what it could be. Is my clutch slipping while it's in gear and the pedal is depressed. I also had it happen to me yesterday when i was backing out of the driveway, but it was in reverse. It jumps like when you have the car in gear, and let off the clutch pedal thinking your in neutral. Thanks for any help.'
Old Aug 5, 2007 | 07:07 PM
cool_junk's Avatar
Default Re: need help, couldn't find a write up on this. (teg-96)
Maybe a bad clutch master. Will the pedal come back up after this happens?
Drew
Old Aug 6, 2007 | 04:05 AM
teg-96's Avatar
Default Re: need help, couldn't find a write up on this. (cool_junk)
the clutch pedal does come back. The car drives fine, and it idles fine to. But if i'm sitting still with the clutch in, and have it in first(as if sitting at a light) the car will occasionally jump like it's trying to take off.
Old Aug 6, 2007 | 11:57 AM
JimBlake's Avatar
So it's not dragging uniformly all the time? I'm thinking something broken, maybe just a piece of friction material from the clutch disk. It occasionally wedges in the pressure plate & drags the clutch, but not always continuously...
Old Aug 8, 2007 | 05:39 AM
teg-96's Avatar
Default Re: need help, couldn't find a write up on this. (JimBlake)
ya, it's not a continual problem. you can sit there with it in gear, and it'll just jump like it wants to take off. Somtimes it jumps so much, that it'll shut the car off unless i give it some gas. kinda like when you put it in gear, and let off the clutch forgetting it was in gear. That jump it does.
Old Aug 8, 2007 | 08:15 AM
JimBlake's Avatar
I think you'll have to take your tranny off & look at the clutch.
Old Aug 8, 2007 | 10:51 AM
93supercoupe's Avatar
no way, dont take the tranny off yet.
Replace the slave cylinder firt, its cheap, then change the clutch master cylinder, THEN take the trans down.
Old Aug 12, 2007 | 12:00 PM
teg-96's Avatar
Default Re: need help, couldn't find a write up on this. (93supercoupe)
ok, i'll look into all that. I'm sure it is the clutch tho. I have to finish a project on a 95 civic, then i'll start working on that. Thanx
91SI92
Apr 23, 2011 11:44 PM
96 EX
11
May 15, 2009 10:29 AM
snzh22
Apr 29, 2008 09:22 AM
2wheelhunter
Aug 30, 2006 07:32 PM
penney
Oct 27, 2005 09:36 AM
