HELP WITH STOCK TRANNY
Old Aug 5, 2007 | 05:03 PM
slowhitEJ1's Avatar
Default HELP WITH STOCK TRANNY
hey guys, kinda in a crunch right now, got to work tomorrow and i started something i can't finish today (stupid) but i'm gonna get as far along as i can tonight so the sooner i can get to work tomorrow.. i'm trying to replace some of the bearings in my 4 speed tranny (DD), and i can't seem to get one off.. this is the one i'm trying to get, but it won't budge with a puller.. can anyone help?
Old Aug 5, 2007 | 07:15 PM
WillieWillieFast's Avatar
Default Re: HELP WITH STOCK TRANNY (slowhitEJ1)
You need one of these. You can find them at your local parts store.
Old Aug 6, 2007 | 06:39 PM
slowhitEJ1's Avatar
Default Re: HELP WITH STOCK TRANNY (WillieWillieFast)
got it.. that' swhat i tried to get it off with, but it wouldn't budge.. it spins freely, but won't come off..
Old Aug 6, 2007 | 07:18 PM
Tippyman's Avatar
Is there a clip or some **** you gotta remove first? I dunno...
Slidehammer? Maybe you shouldn't force it if there's something that needs to be done first to get it off.
Old Aug 6, 2007 | 07:30 PM
mr.speaker's Avatar
When i do this sort of ****,i remove the (1) bolt on the bottom that holds the unit it..when you remove the bolt you can lift the entire assembly out the tranny as one unit.
but a jaw puller should be working
Old Aug 6, 2007 | 08:21 PM
JDM_DC4_Fanatic's Avatar
Default Re: HELP WITH STOCK TRANNY (mr.speaker)
try a lil bit of heat. Sometimes a propane torch does the trick. a lil bit of heat expands the gear just enough to slide over the lip that is stopping it. Thats why it cant be pulled out.
Hold the shaft upside down and apply a lil heat and it should drop right off
B16Jacques
Mar 10, 2007 10:25 PM
petty$rep
Oct 3, 2006 07:02 PM
Boosted-Ek
Sep 13, 2003 06:24 PM
eg6h8k
Jun 21, 2003 12:30 PM
Quik89Si
14
Aug 22, 2002 02:24 PM
