I've given up on the wiring
Old Jun 11, 2002 | 02:35 PM
CivicEx95's Avatar
Default I've given up on the wiring
Well after working on wiring my secondary butterflies on and off for about 2 weeks now, I've given up. I've followed the Helm's manual troubleshooting exactly and they still don't work. I got one wire going directly to A17, and the other one I tapped into the Yel/Blk wire on the PGM-FI main relay. IT DOESN'T WORK. I'm completely clueless on what to do now. Damn thing is pissing me off. Anybody have any suggestions on what to do now? Thanks.
Old Jun 11, 2002 | 02:50 PM
reefer_bob's Avatar
Default Re: I've given up on the wiring (CivicEx95)
Well, first of all, take a step back, take a breath, and let it marinate for a little bit of time. When I have trouble with something on the car, I just take a break, and come back to it.
It might help if you find a friend with a GSR and look at how their wires/hoses are routed and stuff. Have you made sure that the IAB solenoid is working? That its not seized or anything? Do you have a good ground? Do you have a hole in the IAB resoivoir?
Old Jun 11, 2002 | 03:03 PM
junglistgsr's Avatar
what kind of ECU do you have?
Old Jun 11, 2002 | 07:04 PM
CivicEx95's Avatar
Default Re: I've given up on the wiring (junglistgsr)
JDM P72. I might have to find someone that has a ECU I can borrow, cause this **** isn't making sense to me anymore
Old Jun 11, 2002 | 09:09 PM
are all the vacuum lines hooked up correctly?
Old Jun 13, 2002 | 06:46 PM
CivicEx95's Avatar
UPDATE: I decided to manually run power to the solenoid, and it moved! It closed the secondaries. So I double checked all the wiring to the ECU and it IS correct, but it's still not working. So I've ruled it down to the ECU. Anyone else agree?
ericrcan
Feb 29, 2012 04:30 PM
94VTEC2TONE
Mar 6, 2011 09:50 AM
Projectludatic
May 25, 2010 12:29 PM
Hung_Lo
Jun 17, 2007 06:55 PM
bmiller17
Feb 2, 2006 05:42 AM
