1998 CIVIC EX SEDAN...
Old Aug 5, 2007 | 02:24 PM
smarsha_2's Avatar
Default 1998 CIVIC EX SEDAN...
I have a question, hopefully someone can answer it fairly quickly...I can't get the trunk light to work. Isn't it supposed to come on when you open the trunk? How can I fix it?
Old Aug 5, 2007 | 02:25 PM
95ProjectEJ1's Avatar
Default Re: 1998 CIVIC EX SEDAN... (smarsha_2)
Did you check the fuse, bulb and possibly wiring?
Old Aug 5, 2007 | 02:27 PM
smarsha_2's Avatar
Default Re: 1998 CIVIC EX SEDAN... (95ProjectEJ1)
Is there some kind of actuator? Is there a actual fause for the trunk light? I don't get it...
Old Aug 5, 2007 | 03:25 PM
01_CLtypeS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smarsha_2 &raquo;</TD></TR><TR><TD CLASS="quote">Is there some kind of actuator? Is there a actual fause for the trunk light? I don't get it...</TD></TR></TABLE>
should be a fuse for it...pull the fuse cover off the bottom of you dash...it should have a plastic paper on there and it says what fuse is what.
Old Aug 5, 2007 | 03:39 PM
NOFX's Avatar
H-T White Ops
If you don't have the plastic fuse diagram sheet, you can see a full explanation here, and also print out a copy to save.
https://honda-tech.com/zerothread?id=1966666
h3adtr9p
Mar 26, 2019 12:47 PM
Shannon626
May 29, 2008 11:03 PM
asianalbutt
Sep 19, 2005 03:17 PM
guywitaDA
Apr 21, 2004 09:58 PM
