ok what does that click sound when you turn your car on mean? and a solid cel
Old Aug 5, 2007 | 01:09 PM
xXSilentScreamXx's Avatar
Default ok what does that click sound when you turn your car on mean? and a solid cel
well any who my car doesn't click anymore nor does the fuel pump prime?
what could be the problem and i get a solid cel
Old Aug 5, 2007 | 01:16 PM
Archidictus's Avatar
Unceasing Measure
Default Re: ok what does that click sound when you turn your car on mean? and a solid cel (xXSilentScreamXx)
Change your main relay. It sits to the left of the steering wheel under the dash, directly above the hood release latch and should be bolted onto the car's unibody by a 10mm bolt that's particularly annoying to remove. It has a 10-ish pin connector going to it (brown, if memory serves) that you need to remove. Because of the limited space, this will undoubtedly be frustrating.
The click you hear is the relay actuating or, in this case, not actuating It's about $25.
Old Aug 5, 2007 | 01:29 PM
muhaMan's Avatar
Default Re: ok what does that click sound when you turn your car on mean? and a solid cel (Archidictus)
25? i went to the honda dealership 2 weeks ago and they charged me $70!! i guess i got ripped but i have a clean start now
Old Aug 5, 2007 | 01:55 PM
like over here?
Old Aug 5, 2007 | 02:05 PM
Syndacate's Avatar
Default Re: ok what does that click sound when you turn your car on mean? and a solid cel (muhaMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xXSilentScreamXx &raquo;</TD></TR><TR><TD CLASS="quote">well any who my car doesn't click anymore nor does the fuel pump prime?
what could be the problem and i get a solid cel</TD></TR></TABLE>
A solid CEL means no ECU response. Without the ECU the main relay won't activate the fuel pump. So yeah, if your ECU is shot, you won't hear the click of your main relay actuating. Get a response from your ECU first, and then it'll probably work, unless it's blown of course.
DANG YO's Avatar
soild CEL and no fuel pump. bad ecu . i had the same problem.
Old Aug 5, 2007 | 02:27 PM
Default Re: ok what does that click sound when you turn your car on mean? and a solid cel (DANG YO)
how do i check if my ecu is getting power?
Old Aug 5, 2007 | 02:52 PM
ok yea main relay works bc i can hear it click when i try to turn it over
Old Aug 5, 2007 | 03:11 PM
DANG YO's Avatar
try another ecu
Old Aug 5, 2007 | 06:28 PM
i know that my dx one is good how do i check the wiring?
Old Aug 5, 2007 | 07:17 PM
Slammd Sol's Avatar
check ALL your fuses, check/change your main relay, check ALL the engine grounds, perform the main relay test in the helms manual.
Old Aug 5, 2007 | 07:22 PM
Default Re: ok what does that click sound when you turn your car on mean? and a solid cel (Slammd Sol)
i can check all the fuses but idk how to check grounds
Old Aug 5, 2007 | 07:36 PM
Syndacate's Avatar
Like I said before, a solid CEL means that there is no response from the ECU.
After that mess of jumbled and messed up wires you claimed was the ECU harness, it's not a surprise why. I'd say chop the ECU harness off a junkyard car and start wire matching, 'cause that harness is screwed, and if it's not working, your car will never work.
Old Aug 5, 2007 | 07:45 PM
Default Re: ok what does that click sound when you turn your car on mean? and a solid cel (Syndacate)
so i need a 96-98 civic harness auto/manual matter?
Old Aug 5, 2007 | 07:48 PM
94c1v1cex's Avatar
ya it does... i'm pretty sure don't hold me to it though
Old Aug 5, 2007 | 08:15 PM
Default Re: ok what does that click sound when you turn your car on mean? and a solid cel (94c1v1cex)
how do i take off my dash?
Old Aug 5, 2007 | 08:31 PM
hondastrtracr's Avatar
I would have said main relay too, but Im gonna go with ECU also. Pick one up on ebay for 50 bux.
94civiccpe
Jul 18, 2013 07:48 PM
ef8ftw
Oct 5, 2009 07:01 PM
rohec04
Oct 21, 2005 01:18 PM
slickrc
Sep 26, 2004 03:25 PM
Frosty_spl
Apr 22, 2003 03:15 PM
