DC2/I have a couple of problems here>>>
Old Aug 5, 2007 | 12:59 PM
JDMkidGSR's Avatar
Default DC2/I have a couple of problems here>>>
I have a 95 gsr. About 2 months ago I was driving to the track then I pull up to a parking lot to buy something to drink, then my car to smoking from the bottom of the car, Im like damn there goes the headgasket.
Symptoms:
Fluctuating in car temperature
Car dies when AC is on when I give it a small rev.
Car dies when Ac is on and im turning and pressing the brake.
The container where the coolant goes is always empty but has fluid in the radiator.
Another question, I have an oil leak somewhere but I have no clue where its coming from, my thoughts was from the oil pan but then how does it leak on the upper areas.
Final Question is it suppose to have a perfectly square hole on the tranny near the flywheel.
Help me out please.
Old Aug 5, 2007 | 01:25 PM
frontwheelfanatic's Avatar
Default Re: DC2/I have a couple of problems here>>> (JDMkidGSR)
change your thermostat and clean the idle control valve thats mounted on the bottom of the intake manifold to see if that fixes your problems.
what area is the oil coming from? any engine codes?
Old Aug 5, 2007 | 02:00 PM
JDMkidGSR's Avatar
Default Re: DC2/I have a couple of problems here>>> (frontwheelfanatic)
i dont have any engine codes.
Old Aug 6, 2007 | 11:03 AM
JDMkidGSR's Avatar
bump...need help
Old Aug 6, 2007 | 11:07 AM
iH8RICERZ's Avatar
can't really tell, but I've had a leak under my car before as well.....traced it back to my oil pan. The bolts were coming lose and it was time to replace the gasket. As for your stalling problems and fluctuating gauges, cant help you out there. How many miles are on the car?
Old Aug 6, 2007 | 06:18 PM
JDMkidGSR's Avatar
Default Re: DC2/I have a couple of problems here>>> (iH8RICERZ)
About 166000
Old Aug 6, 2007 | 06:23 PM
Bowers's Avatar
Wouldn't hurt to run a compression and leak down test as well. Any vaccum leaks anywhere? I see that you no longer have the dual stage gsr intake manifold.
Old Aug 12, 2007 | 11:49 AM
JDMkidGSR's Avatar
Default Re: (tunergsr32)
Bump, no I dont have any vacumm leak. idle is good.
Idles at 900 when its night and idles at 600 when its hot and then thats when it usually dies on me. And AC is on.
Old Aug 12, 2007 | 12:04 PM
LDS's Avatar
LDS
Funny. I have the same idle and coolant problem like you. Make sure theres no air bubbles in the coolant system and definatly check the compression. Also if your headgasket is leaking or blown it will usually blow bubbles in the coolant overflow tank when the car is running, another clue is the oil and coolant somtimes mix making a milkshake looking fluid.
Old Aug 12, 2007 | 12:23 PM
integraRS-T's Avatar
Default Re: (LDS)
yeap look at ur dipstick if it looks like milk ur hg took a ****
Chrisdotcom
Apr 20, 2009 06:17 AM
James
Apr 30, 2007 09:08 PM
my97accord
Jul 1, 2005 12:43 PM
vxnine
May 16, 2004 05:33 PM
