Vtech Solenoid
Old Aug 5, 2007 | 09:48 AM
flight50's Avatar
Default Vtec Solenoid
Okay searching didn't help me one bit. My vtec isn't engaging anymore every since I did my auto to 5spd swap. I am trying to narrow my possibilities down. I tested out the solenoid. I cleaned the screen. It does work hooking it to the battery.The vtec solenoid valve thingy moves. It springs back. It pushes in with a lil effort, not much. Is this normal. My oil pan was dented so i replaced that and the oil pick up was damaged so that got replaced as well. Did an oil and filter change. Dip stick is past the the second mark a lil. I still run the auto p13 without the tcu dis-connected. And yes my vss works fine. And yes the car is at running temps when I try. When i had my auto it kicked in at 5200 so I know when its suppose to happen. I even take it up to 6200 and still nothing. The solenoid and oil switch are connected and no wires were severed. I am running out of options. My throttle cable as a bit of give to it. Is this related to vtec engagement at all. I don't have idle problems though.
Modified by flight50 at 1:29 PM 8/5/2007
Modified by flight50 at 2:31 PM 8/5/2007
Modified by flight50 at 2:34 PM 8/5/2007
Modified by flight50 at 8:31 PM 8/5/2007
Old Aug 5, 2007 | 11:45 AM
98vtec's Avatar
moderator emeritus
Default Re: Vtec Solenoid (flight50)
https://honda-tech.com/zerothread?id=830163
Old Aug 5, 2007 | 05:34 PM
flight50's Avatar
Default Re: Vtec Solenoid (98vtec)
was this a sticky. cool thanks. i will go thru and hopefully one of the things i haven't tried works.
jasonboyce03
Oct 15, 2011 03:20 AM
blacktibby07
May 14, 2011 11:12 AM
DC2_ITR
Apr 27, 2007 12:55 PM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
dumpeDc2
Feb 25, 2005 06:08 PM
