honda accord 99 a/c
ur the man... i checked the the manual, and it says r 134a
the one which i bought from the auto store "ez chill R-134a refrigerant plus oil" under the instructions it says the low pressure port of the a/c system usually has a blue or black dust cap and is located on the larger diameter tubing that runs between the evaporator (in the dash board)and the compressor (on the engine)
now i have a blue cap one in front of the radiator and a black one behind the radiator, i was under the impression i should fill where the blue cap is but when i read the instructions on the ezchill it seems to be the one behind the radiator
when i checked out with my friend he said that one of them is for the refrigerant and the other one is for oil and should take care where you put the refrigerant
do you have any suggessions? please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tech8 »</TD></TR><TR><TD CLASS="quote">In 92-93, I believe Honda switched over from R-12 to R-134a...</TD></TR></TABLE>
'93 was the first year of R134A in Saturns, there must have been some new regulation.
Edit: Must have been '94. I was with an ex-girlfriend when she was buying a '93 Saturn, the type of refrigerant was brought up as a change for '94 so the '93 had R-12.
Modified by Heat at 12:55 AM 8/6/2007
you should add refrigerant in the line that runs out of the firewall on the passenger side of the motor. can't remember if it s high or the low, but i think it should tell you that on the can. i know some have refrigerant and an oil both in the can. Also i dont think you can even buy r-12 anymore? i know you can get conversion kits.
thanks for all the info guys, actually the low pressure **** has an L and the high pressure **** has H on it. i filled it with r134a and its working fine.
another quick question.
my friend came the other day and he unlocked my car using the key and the alarm went off, then he used the remote to turn it off. since then my alarm is disabled but i can use my remote to unlock and lock the car but without any sound.
how do i enable my alarm again? pls help
Anderson
Mar 19, 2003 11:36 AM
