trans/axle grinding noise
Old Aug 5, 2007 | 04:41 AM
mtownsi's Avatar
Default trans/axle grinding noise
hey wats up. i have a 99si stock b16 trans. i know its a wierd ? cuz u cant hear the noise or anything. i just thought maybe some had it happen before. so i was driving started hearing a grinding noise so i jacked it up taa home thought it might be tr brakes there all good. i put the car in gear while on jackstands to let the tires spin. and right were the pass. axle goes into the tranny its grinding. oil is good in tranny and axle is good. i havnt pulled the axle yet but any ideas ? or suggestions ?
Old Aug 5, 2007 | 10:27 AM
95sloweg's Avatar
Default Re: trans/axle grinding noise (mtownsi)
Is the axle all the way in?
Old Aug 5, 2007 | 11:31 AM
mtownsi's Avatar
Default Re: trans/axle grinding noise (95sloweg)
yea the axle is all the way in it has a little play but thats usuall correct?
Old Aug 5, 2007 | 12:30 PM
slowcivic2k's Avatar
Jack it up and block one wheel and watch the other spin and note the noise it makes. Then do it to the other wheel.
I would need more information, does it make sound on a turn? If so which way.
What kind of grind, like a growl?
Side gears/pinions could be a culprit, could also be something in the axle/wheel bearing.
Old Aug 5, 2007 | 02:36 PM
95dsol's Avatar
yeh the axle has to be all he way in lol it has a lil sliver at the end of the axle thatgoes into the tranny and if its not tall the way in it will kick out allmost immediatly
Old Aug 5, 2007 | 02:38 PM
mtownsi's Avatar
Default Re: trans/axle grinding noise (slowcivic2k)
yea i did that the pass side is the only side that makes the noise it sounds like gears grinding but it only does it at slow speeds but at high speeds i get like a birdchirp/squeak if i turn the wheel just a lil bit
EJ8_Enthusiast
Suspension & Brakes
Apr 19, 2013 05:29 AM
blasterman87
Nov 30, 2009 08:09 PM
iwanaturboteg
Apr 29, 2008 11:16 AM
penney
Apr 16, 2004 06:58 PM
Aug 13, 2002 06:30 PM
