Help, Headlight install
ok i have a 92 civic si and i need to replace one of my headlight bulbs. the one problem im having though is how to gain access to the bulb. the washer fluid and the power steering fluid are both blocking to gain access. can anyone help me figure out what i need to do. thank you
i removed the power steering tank, just pulled up and just held it to the side and squeezed my hand to it. Or you could drain the power steering fluid into a coke bottle and undo the hoses and do it that way.
I have hands small enough to change a bulb without removing anything, but yes, pull up on the power steering reservoir will release it from it's mount and give you enough room to change the bulb. In fact, Honda's owner's manual even tells you to remove it to change the bulb.
thaddeus
17
Jan 11, 2015 10:36 AM
granracing
Apr 7, 2005 02:32 PM
Hazem
Dec 17, 2004 07:12 PM
magic hat #9
Jul 16, 2003 08:00 PM
