LS/VTEC...what head?
Old Aug 4, 2007 | 09:18 PM
EK 2 9K's Avatar
Default LS/VTEC...what head?
hey guys my buddy is interested in doing and ls/vtec. hes got a DA right now and the stock ls just isnt doing in for him. i heard that the b16 head is the best flowing head....true or false? if it is false then what head is best? what would also be the best cam set up without breaking the bank? thanks in adavance.
Old Aug 4, 2007 | 10:58 PM
lunatics209's Avatar
Default Re: LS/VTEC...what head? (EK 2 9K)
b16 head in a DA is better. i think with the gsr head you have to make a custom intake cause of how the manifold sits. cam set up would be just itr or ctr. you can find them for 250-300.
Old Aug 4, 2007 | 11:21 PM
EK 2 9K's Avatar
Default Re: LS/VTEC...what head? (lunatics209)
^^^thanks any other opinions?
Old Aug 5, 2007 | 05:35 AM
BIGGA-Z's Avatar
I WOULD GO WITH B16 HEAD DUE TO THE FACT IT CAN BOLT THE ITR/CTR INTAKE MANIFOLD BUT FOR CR B18 IS BETTER BUT YOU'll HAVE TO GET SKUNK2 INTAKE.
Old Aug 6, 2007 | 09:14 PM
EK 2 9K's Avatar
Default Re: LS/VTEC...what head? (BIGGA-Z)
bump
Old Aug 6, 2007 | 09:35 PM
smileycvc's Avatar
B16 hands down. Flows better and the design is alot more simple. Also do a search this has been covered a thousand times.
Old Aug 6, 2007 | 10:25 PM
VRD^sam's Avatar
Default Re: LS/VTEC...what head? (smileycvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">B16 hands down. Flows better </TD></TR></TABLE>
Old Aug 6, 2007 | 10:41 PM
SYTFU Tommy.'s Avatar
Default Re: LS/VTEC...what head? (VRD^sam)
blah...i remember that there was a flow chart some where floating around h-t..
B16&lt;GSR&lt; ITR
people got to remember that the itr which is the b16 will outflow both since it is mildly ported and polish. a regular b16 head will not outflow a gsr head too....
Old Aug 6, 2007 | 11:03 PM
smileycvc's Avatar
Default Re: LS/VTEC...what head? (SYTFU Tommy.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYTFU Tommy. &raquo;</TD></TR><TR><TD CLASS="quote">a regular b16 head will not outflow a gsr head too....</TD></TR></TABLE>
That last part didnt really make sense are you saying a B16 will or will not outflow a GSR.
1. ITR
2. B16
3. GSR
Thats just the way it is.
Old Aug 6, 2007 | 11:13 PM
VRD^sam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYTFU Tommy. &raquo;</TD></TR><TR><TD CLASS="quote"> a regular b16 head will not outflow a gsr head too....</TD></TR></TABLE>
Old Aug 6, 2007 | 11:15 PM
GSR&gt;B16 head flow wise.
Old Aug 7, 2007 | 12:33 AM
smileycvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYTFU Tommy. &raquo;</TD></TR><TR><TD CLASS="quote">GSR&gt;B16 head flow wise.</TD></TR></TABLE>
I dont think so. Where did you hear this? I read that the B16 head out flowed the GSR head until they hit .450 valve lift. So unless your running a ridiculous cam the B16 is gonna flow better.
Old Aug 7, 2007 | 04:16 PM
EK 2 9K's Avatar
thanks for the help....keep this going i would like to know what wins, b16 or ITR
Old Aug 7, 2007 | 05:06 PM
smileycvc's Avatar
Well now if you want to narrow it down between the B16 and the ITR it the ITR for sure. It is a hand polished B16 head. It also has a more aggresive cam and a stiffer valvetrain. However if you plan on doing any head work anyways just buy a b16 head and save the money toward a set of cams or a port an polish.
Old Aug 7, 2007 | 09:51 PM
5_Lug_B's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc &raquo;</TD></TR><TR><TD CLASS="quote">Well now if you want to narrow it down between the B16 and the ITR it the ITR for sure. It is a hand polished B16 head. It also has a more aggresive cam and a stiffer valvetrain. However if you plan on doing any head work anyways just buy a b16 head and save the money toward a set of cams or a port an polish. </TD></TR></TABLE>
x2
Old Aug 7, 2007 | 10:00 PM
94typeR's Avatar
theres a flow sheet around that shows b16 and gsr is pretty much the same flow rate
Old Aug 7, 2007 | 10:19 PM
95TegSE's Avatar
Default Re: (94typeR)
I don't want to get into the flow debate, but the GSR head will net you a higher CR due to its slightly smaller combustion chamber.
Old Aug 7, 2007 | 10:58 PM
smileycvc's Avatar
Default Re: (95TegSE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94typeR &raquo;</TD></TR><TR><TD CLASS="quote">theres a flow sheet around that shows b16 and gsr is pretty much the same flow rate</TD></TR></TABLE>
Yeah its really close the GSR will actually flow better, but it requires a huge cam. Alot of people dont take into consideration the lift and duration.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TegSE &raquo;</TD></TR><TR><TD CLASS="quote">I don't want to get into the flow debate, but the GSR head will net you a higher CR due to its slightly smaller combustion chamber.</TD></TR></TABLE>
Also true.
Midori Green
Feb 23, 2008 06:57 PM
wechill187
Nov 16, 2006 01:18 PM
2gen_tegs_rule
Feb 6, 2006 12:29 PM
master honda tech
Mar 24, 2005 12:58 PM
delsolracer
Jul 19, 2001 06:06 AM
