itr jdm tranny question...
ok... i bought my integra with a jdm itr engine and tranny. both are stamped with proofmarks from hmotors. the tranny is supposed to have lsd but it does not. The opposing wheel does not turn when on the racks. so heres my dillema. is this just a regular gsr s80 transmission or a itr without the lsd? Im idling at 4400rpm @ 80mph.
thanks
thanks
its not a gsr transmission if its at 4400 rpm at 80 mph, if it was a gsr tranny, itd be at 4000 at 80.
Youve got either a b16 tranny or a itr without an lsd...
I dunno whats up with that, thats just weird.
There is the ones in black that usually is somewhat under the vtec cylanoid! But the best way to find out if that tranny has LSD or not, is to take out the pass side axle! look inside to see if there is a shaft! If you dont see a shaft then its LSD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLEEPER775 »</TD></TR><TR><TD CLASS="quote">The opposing wheel does not turn when on the racks. </TD></TR></TABLE>
The car has to be gear for that to work. Search google for "hondahookup manuals". Download the 97 ITR supplement and run through the LSD check procedure. You can also pull an axle and look for the straight through shot in the differential.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror »</TD></TR><TR><TD CLASS="quote">It must be in gear when you rotate the tires. Put the car in first gear and rotate the tires again</TD></TR></TABLE>
big ups
big ups
BTW: the stock ITR LSD will superficially behave like an open differential when you rotate a wheel with the car in gear and in the air. You need to perform a torque measurement as outlined in the Helm to verify the operation/presence of the LSD.
SPOON_BeIgHtEeNsEe
Dec 27, 2001 01:25 PM
