problem with vtec
i have a 98 civic d16. i have read that if the cel is on then it want let the vtec work? if this is true could i not just wire the silonid to a button and work it that way till i got my cel off? i not really sure how all that works. someone please help
when the cel is on, it puts the car into limp mode. you can't go above 3500 for a reason, its so you wont damage your engine internals. read the CEL sticky and find out what code you are throwing. you need to get this cleared up before you try to hotwire some **** and expletive your car up. then you'll be asking how to do an engine swap next....
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">when the cel is on, it puts the car into limp mode. you can't go above 3500 for a reason, its so you wont damage your engine internals. read the CEL sticky and find out what code you are throwing. you need to get this cleared up before you try to hotwire some **** and expletive your car up. then you'll be asking how to do an engine swap next....</TD></TR></TABLE>
lol no no this isnt a volkswagen. When the CEL turns on, it just means there's a fault with whatever component that the CEL is on for. The car will still go to redline unless there's a mechanical fault that's preventing it from doing so. The ECU does not limit RPMs under redline for anything except speed cut. Which, I believe, only happens with JDM ECUs.
VTEC needs these things to activate:
VTEC solenoid and oil pressure signal (duh)
Certain RPM (duh)
Coolant at normal operating temperature (The ECU has to be able to recognize
this electronically thru the coolant temp sensor)
Oil pressure
Speed sensor signal (car is moving)
Throttle input
It will activate unless something mentioned ^^ above is not right.
Vtec may or may not operate for you depending on what your CEL is for. Find out...and have it fixed. Easy sleazy.
Certain RPM (duh)
Oil pressure
Throttle input
98exturd, that's not true. You can have a CEL and the vtec still work, depending on the code that it is throwing. You should find out what the codes are so you can see if they have anything in relation to your vtec or just other problems with the car that need fixed. In addition to the comment b serious left, check your knock sensor. When my knock sensor broke, it disabled my vtec. Don't try to hotwire something up though. It will only cause problems for you in the future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98exturd »</TD></TR><TR><TD CLASS="quote">i have a 98 civic d16. i have read that if the cel is on then it want let the vtec work? if this is true could i not just wire the silonid to a button and work it that way till i got my cel off? i not really sure how all that works. someone please help</TD></TR></TABLE>
It depends on what CEL it is, if it's a VTEC related check engine light then it won't work. If it's not a VTEC related CEL, it will still function fine.
A CEL will NOT throw it into limp mode like gsxr1k05 says it would unless it's something catastrophic (like your knock sensor is detecting a knock).
Use this link to find out your CEL:
https://honda-tech.com/zerothread/1901557
Find out what CEL you're throwing and get back to us.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98exturd »</TD></TR><TR><TD CLASS="quote">its the secondary o2 sensor</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">b serious, while you are correct, wouldn't the sec. o2 have something to do with vtec sense it helps manage fuel delivery
the SECONDARY O2 has nothing to do with fuel delivery. It's a monitor. It monitor's the cat's function. The primary controls fuel delivery.
The primary O2 voltage will jump between 0(lean) and 1(rich) volts back and forth over and over to keep adjusting fuel delivery in CLOSED LOOP OPERATION. (car warmed up, at a constant, lower percentage throttle opening)
The secondary O2 voltage should stay relatively constant. around 0 volts. It should be seeing mostly oxygen. That's how it knows that the cat is working and present.
OP: is your cat present? maybe your secondary O2 is bad and it needs replacement....maybe there's bad wiring. You'd have to look at it.
It has NOTHING to do with VTEC, however.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
Find out what CEL you're throwing and get back to us.</TD></TR></TABLE>
hondas dont really have a "limp mode". If it knocks...the ECU just retards timing as much as it can until it cant anymore. That's why turbo cars with piggybacks still blow up. There's really no limp mode.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98exturd »</TD></TR><TR><TD CLASS="quote">so why is my vtec not comin in. vtec is some then that is easy to tell when it comes in right?</TD></TR></TABLE>
depends on the car. have you ever been able to notice your vtec cross over?
D series VTEC only comes on on the intake side. If you have an exhaust, it sometimes drowns it out.
What kind of car? what mods?
ok i have a 98 civic ex. i dont know about the cross over thing? i bout the car with no motor and then put one in. and i have an intake and full exuast. i dont know what kind all i know is its really loud and sounds like dammit. so are you saying maybe i dont hear it. my gf used to have a 00 si and you could really hear it. but wouldnt i feel it?
00 si has a B16A. DOHC vtec is usually VERY noticeable. Except for on the GSR.
What motor is in your car?
Single cam VTEC is usually not too noticeable. The D16Y8 has a pretty loud cross over (primary camlobe to VTEC camlobe change) for a SOHC. SOHC vtec only happens on the INTAKE side. So yes, if you have a very loud exhaust, it will drown out the VTEC noise.
If this is a SOHC, it's not going to sound ANYTHING like a B16A's loud *** VTEC. Nor will it feel like it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious »</TD></TR><TR><TD CLASS="quote">00 si has a B16A. DOHC vtec is usually VERY noticeable. Except for on the GSR.</TD></TR></TABLE>
are you saying its not noticable on gsr motors???? i can feel the vtec in my boys 4dr gsr..IMO you really cant feel SOHC vtec once you feel the vtec from a DOHC you will know what it is suposed to sound and feel like...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blanco617 »</TD></TR><TR><TD CLASS="quote">
I have a 99 gsr with an intake, header, and skunk2 manifold. Since VTEC engages at 4500, you really cant hear it that well. If you have the stock manifold, you can hear and the butterflies open at 6k. A lot of people think that VTEC is at 6k on GSRs.
Or maybe I'm spoiled lol. I had a B16A with skunk manifold, intake, header, exhaust....and that was a super loud crossover. I also have an S2000 with an intake...it sounds like the apocalypse when it goes into VTEC.
oOo well on all my gsr motors my vtec kickd hard one of them chirped the tires when vtec engaged at 4500k. the type r motor i had hit really hard vtec i had an edelbrock intake manifold on it and it was kick ***
hondas dont really have a "limp mode". If it knocks...the ECU just retards timing as much as it can until it cant anymore. That's why turbo cars with piggybacks still blow up. There's really no limp mode. </TD></TR></TABLE>
Well I've never actually seen it's limp mode but I know it has it. I just assumed it had to be catastrophic to engage since I've seen it all and no limp mode.
You can't feel jack **** in a SOHC, but you can definitely notice the pitch change. Especially if you have a louder exhaust.
You can't feel jack **** in a SOHC, but you can definitely notice the pitch change. Especially if you have a louder exhaust.</TD></TR></TABLE>
well...you'd notice it LESS with a louder exhaust since the VTEC is only active on the intake side on a SOHC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98exturd »</TD></TR><TR><TD CLASS="quote">so to be sure its working how would i tell?</TD></TR></TABLE>
Set up a LED to light when the VTEC solenoid grounds out.
Usually when VTEC is inoperable, there is a check engine light either for the VTEC solenoid/pressure switch, or there is a CEL for some of the other things that i said before. Like a coolant temp sensor CEL or a speed sensor CEL for example.
