1993 honda accord - d4 flash intermittent start
From what I have read on here so far it sounds like i have a bad main relay. I cant id this relay... there is a black box with a few chips in it and it looks like 3 relays over it which is over the fuse box... hard to get to.... which is the main relay?
It has all the classic symtoms as laid out in:
http://techauto.bravehost.com/
Help
Robert
Modified by ddg2sailor at 5:08 PM 8/4/2007
Help
Robert
nope sounds like you are looking in the wrong place.
the main relay is to the drivers side of the steering column above the cruise control unit. All you can see of it is the bottom where the plug is.
You have to lay on your back on the drivers floor board and look straight up
Your right.... Its right under the cruise control unit... Cant see it without removing it.
This page was a lot of help :
http://techauto.te.funpic.org/mainrelaydefine.php
Thanks
Robert
Thanks
Robert
I replaced the rz-0088 with a used one and it seems to start faster now... Not that it was so bad before when it wasnt too hot.... it just catchs as soon as I turn the key now.
Thanks for all your help!
Robert
Robert
deadhead23
Jan 15, 2021 10:43 AM
jm3d
Mar 2, 2018 03:19 PM
closs2sx
Oct 28, 2008 05:48 PM
romeoz24_2000
Aug 12, 2008 04:03 AM
