}}} Does this block look sleeved? {{{
Old Aug 4, 2007 | 01:22 PM
slow poke's Avatar
Default }}} Does this block look sleeved? {{{
The sleeves are about 7mm or so thick and there spaced about 7mm from the block's wall at the smallest point. Bore is either 81mm(stock) or 81.5mm. What do you guys think? Didn't seem like there was any way a block guard my friend had lying around would ever fit in the block. I have never built a motor so I have no clue here. Let me know what you think. Thanks
Click on pics for larger version.
Old Aug 4, 2007 | 01:31 PM
tony413's Avatar
yes
Old Aug 4, 2007 | 01:34 PM
slow poke's Avatar
Default Re: (tony413)
Obviously I am talking about aftermarket sleeves here...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">yes </TD></TR></TABLE>
Any idea what company did it? How can you tell?
Thanks
Old Aug 4, 2007 | 04:22 PM
drumking15's Avatar
stock replacements....not aftermarket
Modified by drumking15 at 2:29 PM 8/5/2007
Old Aug 4, 2007 | 04:48 PM
Mr HYDE's Avatar
Default Re: (drumking15)
the 2 tone sleeve leads me to believe they are stock
Old Aug 4, 2007 | 04:55 PM
tokesGTR's Avatar
if tony413 says yes, you can bet money it's going to be a no.
Old Aug 4, 2007 | 05:03 PM
slow poke's Avatar
Default Re: (tokesGTR)
Everybody makes mistakes... Bump for some more input.
Thanks
Soccerking3000's Avatar
they are not stock those are darton press in sleeves, notice how much thicker the iron part of the sleeve is? The engine is sleeved, i'd put money on it, not to mention that each iron liner is touching the adjacent liner where in a stock motor they would be just barely touching if at all
Old Aug 4, 2007 | 05:09 PM
slow poke's Avatar
Default Re: (Soccerking3000)
Those were the exact same indications that were leading me to believe they were not stock. The sleeves seemed allot thicker then I remembered. Plus, the block guard didn't seem like it would EVER fit in there but again I am not 100% on that.
Please keep the opinions coming
Old Aug 4, 2007 | 05:10 PM
SovXietday's Avatar
[QUOTE=Soccerking3000]they are not stock those are darton press in sleeves, notice how much thicker the iron part of the sleeve is? The engine is sleeved, i'd put money on it, not to mention that each iron liner is touching the adjacent liner where in a stock motor they would be just barely touching if at
x2, definitely darton sleeves.
Old Aug 4, 2007 | 05:17 PM
Default Re: (SovXietday)
i dont think there needs to be any more "opinions" the block is sleeved, they arent full replacement sleeves but it IS sleeved and will do its purpose.
Old Aug 4, 2007 | 05:19 PM
nvmyb20hatch's Avatar
i had a motor that was very similar to this that was sleeved by arias, who subleted theyre work to rs machine for their open deck sleeves a few years ago. they used dartons for the closed deck sleeve design, but this is rsmachine. search arias sleeves in archived
Old Aug 4, 2007 | 05:31 PM
slow poke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think there needs to be any more "opinions" the block is sleeved, they arent full replacement sleeves but it IS sleeved and will do its purpose.</TD></TR></TABLE>
Id like more opinions as everyone is not really in an agreement at this point. I believe you that it is I am just trying to see what other people have to say. I would like to find out the brand as well if possible. Thanks
Iv never heard of a difference between "full replacement" and non- full replacement. I know most companies leave some part of the stock sleeves, is that what you are talking about?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nvmyb20hatch &raquo;</TD></TR><TR><TD CLASS="quote">i had a motor that was very similar to this that was sleeved by arias, who subleted theyre work to rs machine for their open deck sleeves a few years ago. they used dartons for the closed deck sleeve design, but this is rsmachine. search arias sleeves in archived</TD></TR></TABLE>
So you believe these were done by RS Machine? Does RS machine use darton sleeves for open deck or do they have there own?
Thanks
Old Aug 4, 2007 | 05:40 PM
1995Civic's Avatar
Default Re: (slow poke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">
Id like more opinions as everyone is not really in an agreement at this point. I believe you that it is I am just trying to see what other people have to say.Thanks</TD></TR></TABLE>
If you search HT a little more, you will find that not everyone will always agree
The block is sleeved as SoccerKing stated. I would listen to that person...the knowledge is definitely there!
Old Aug 4, 2007 | 05:44 PM
Mr HYDE's Avatar
Default Re: (1995Civic)
darton and benson are a solid cast iron sleeve, those ones pictured look to be 2 materials.
Old Aug 4, 2007 | 06:04 PM
slow poke's Avatar
Default Re: (Mr HYDE)
Old Aug 4, 2007 | 06:39 PM
GiNuWiNe's Avatar
It's sleeved, stock sleeves are thinner compared to those.
Old Aug 4, 2007 | 07:25 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr HYDE &raquo;</TD></TR><TR><TD CLASS="quote">darton and benson are a solid cast iron sleeve, those ones pictured look to be 2 materials. </TD></TR></TABLE>
darton makes press in iron liners that are thicker than stock and are not a complete replacement.
As for the different between a full replacement sleeve and a partial replacement, a full replacement, replaces the iron liner and the outer aluminum liner with a solid ductile iron sleeve, a partial replacement replaces just the inner iron liner with a thicker one while still leaving part of the aluminum outer support there.
Old Aug 4, 2007 | 07:27 PM
rainmanEK's Avatar
big strong guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokesGTR &raquo;</TD></TR><TR><TD CLASS="quote">if tony413 says yes, you can bet money it's going to be a no.</TD></TR></TABLE>
Haha
Eric
Old Aug 4, 2007 | 07:33 PM
Default Re: (rainmanEK)
and as i look at the pictures more the outer ring might not even be aluminum and might just be from the headgasket seal, but i can't tell for certain
Old Aug 4, 2007 | 08:01 PM
GetawayInMoscow's Avatar
Looks kinda like AEBS sleeves
Old Aug 4, 2007 | 08:48 PM
riceball777's Avatar
Default Re: (GetawayInMoscow)
yes the block is sleeved and they are not stock sleeves
the people that say its stock sleeves are blind
Old Aug 4, 2007 | 10:02 PM
5150chubbs's Avatar
there not AEBS sleeves
Old Aug 4, 2007 | 11:00 PM
tony413's Avatar
whats your problem leave me out of your post i've done nothing to you expletive off
Old Aug 4, 2007 | 11:04 PM
SlowReaction's Avatar
Those are aftermarket sleeves. You can tell because each clyinder has a a line that shows that there individual sleeves. This style is like the Benson ,Rs machine style.
