Wet Sanding Headlights
Old Aug 4, 2007 | 11:37 AM
disposable's Avatar
Default Wet Sanding Headlights
Ok, well I'm not sure if this is where i put this but I figure it is probably the best place to put it because it involves wetsanding.
My question is..
Whats the best way to wetsand headlights that are starting to yellow? I want to make my headlights clear again when i DIY paint them black on my 98 coupe. only one i starting to yellow at the top. anyone got any tips for me or anything?
Thanks
Old Aug 4, 2007 | 03:15 PM
SoullessJapaneseMachine's Avatar
Default Re: Wet Sanding Headlights (disposable)
https://honda-tech.com/zerothread?id=1523524
Old Aug 4, 2007 | 07:58 PM
gianinline's Avatar
Sure.... sand with 1000 grit first... Then... 1500..... (you could go ahead and buff).. but... to get a even better result... do 2000 grit... and buff... (if have in hands 3000..why not?!).
I do that all the time on customers cars....
Old Aug 6, 2007 | 02:11 PM
lazybrown187's Avatar
Default Re: (gianinline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gianinline &raquo;</TD></TR><TR><TD CLASS="quote">Sure.... sand with 1000 grit first... Then... 1500..... (you could go ahead and buff).. but... to get a even better result... do 2000 grit... and buff... (if have in hands 3000..why not?!).
I do that all the time on customers cars....</TD></TR></TABLE> WHAT THIS GUY SAID!!!!
Old Aug 6, 2007 | 02:19 PM
Red_ED8's Avatar
Default Re: (lazybrown187)
Be carefull when buffing your headlights. Plastic will burn very easily. So if you never bufffed before, don't learn on your headlights (unless you have spairs).
Old Aug 7, 2007 | 08:17 AM
battlecrxT's Avatar
honda-tech is the bomb,I was reading something on 3m compound rub and a small buffer. Does this make any sense?
Old Aug 7, 2007 | 03:36 PM
kalbs's Avatar
yup...i already did this...i used 2000 grit... although i dont think i did enough...but still the results wer gud
Old Aug 7, 2007 | 06:03 PM
thedispatcher's Avatar
i never knew they had 3k grid..i thought 2k was the highest?
Old Aug 7, 2007 | 06:20 PM
SkankyEJ7's Avatar
Default Re: (thedispatcher)
nah the 3000 i dont think you can get at like vato zone
Old Aug 9, 2007 | 11:12 PM
EKFerioHawaii's Avatar
I have 4k grit in my stash.
I use 2k then 3m compound on a 3" pad. Or when I am lazy, 2k and mother's
mag & aluminum polish. Try it, does wonders.
Old Aug 10, 2007 | 07:26 AM
Genuine Rolla's Avatar
Blue Magic Metal polish and then some Black magic liquid wax.
Old Aug 10, 2007 | 11:26 AM
Pac-Man_G's Avatar
Default Re: Wet Sanding Headlights (SoullessJapaneseMachine)
i say use 3m's medium grit rubbing compond buff it out clean it off with a cleam rag. then 3m refinishing compond. and be done with it
Old Aug 10, 2007 | 09:34 PM
DjMigs's Avatar
Is it yellowing with scratches/gouges or just yellowing....
if just yellowing i would suggest Meguiars #80 it will remove the oxidation and polish @ the same time (but i would use the with a pc ) alternative is Megs DC #1 but i prefer #80 (paint and body supply) then apply protection ...
gl
davidluko
Jul 1, 2007 09:50 PM
d16civic111
12
Jul 13, 2006 12:53 AM
S1_DJai
Oct 21, 2005 12:56 PM
EJ8VTEC
Oct 1, 2005 04:19 PM
azian21485
Dec 8, 2003 12:54 PM
