Competition Clutch SALE 10% off Retail wih Free Shipping in Continental US
Having a SALE on all Competition Clutch Products , 10%+ Off Retail with FREE SHIPPING IN CONTINENTAL US
Additonal product info can be found here http://www.competitionclutch.com or contact me with any questions and PRICING
Stage 1 - Gravity Series 2400 Clutch Kit
The economical solution for moderately modified cars or simply aggressive individuals with stock power. Offers 40-50% of torque capacity and maintains stock pedal feel.
DO NOT use with added forced induction such as turbo, supercharger, or NOS systems.
The 2400 Series kit includes a Competition Clutch pressure plate, a 6 pad Carbotic high-torque performance disc assembly, all applicable bearings and the appropriate alignment tool.
Stage 2 - Street Series 2100 Clutch Kit
This assembly provides approximately 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Carbon Kevlar material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life.
The 2100 Series kit includes a performance pressure plate, a high torque sprung disc with antiburst steel backed Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool
Stage 3 - Street/Strip Series 2300 Clutch Kit
This segmented Carbon Kevlar material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for 150% increase in torque capacity. Provides quick but smooth engagement and extended life. 500 mile break-in REQUIRED with this set-up.
The 2300 Series kit includes a performance pressure plate, a high torque sprung disc with segmented Carbon Kevlar facings, all applicable bearings, and the appropriate alignment tool.
IronMan Street/Strip Series 1680 Clutch Kit
This assembly features our advanced hybrid iron and carbon friction material riveted to our high torque disc assembly in a six puck style. The IronMan provides outstanding stability, smooth engagement, and less wear on opposing surfaces. Offers 175% increase in torque capacity.
The 1680 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Iron/Carbon buttons, all applicable bearings, and the appropriate alignment tool.
Stage 4 - Strip Series 1620 Clutch Kit
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 250% increase in torque capacity.
The 1620 Series kit includes a performance pressure plate, a six puck high torque sprung disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
Stage 4 - Strip Series 0620 Clutch Kit
This assembly, available with a six puck rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 250% increase in torque capacity.
The 0620 Series kit includes a performance pressure plate, a six puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment tool.
Stage 5 - Strip Series 1420 Clutch Kit
This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides 300% increase in torque capacity.
The 1420 Series kit includes a performance pressure plate, a four puck high torque sprung disc Ceramic buttons, all applicable bearings, and the appropriate alignment
Stage 5 - Strip Series 0420 Clutch Kit
This assembly, available with a rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides 300% increase in torque capacity.
The 0420 Series kit includes a performance pressure plate, a four puck high torque rigid disc with Ceramic buttons, all applicable bearings, and the appropriate alignment
Forged Ultra Lightweight Steel Flywheel
The STU flywheel is recommended for forced induction and/or track and rally racing applications. This flywheel will work with ALL performance and stock clutch assemblies.
Qualities of the CCI Ultra Lightweight Steel Flywheel:
One piece ring gear for high durability
Weight varies from 8 lbs. to 10 lbs. depending on application
Well suited for Stage 3 and up clutch kit applications
Stamped with 4140 plate with 2000 ton pressure at 1260 degrees
CNC machined and balanced to O.E. specifications
Reduced Mass = Increased Accleration
Meets and exceeds SFI 1.5
Forged Lightweight Steel Flywheel
The ST flywheel is recommended for naturally aspiriated and/or street driven applications. This flywheel will work with ALL performance and stock clutch assemblies.
Qualities of the CCI Lightweight Steel Flywheel:
Preserves low end torque and drive ability
Weight varies from 11 lbs. to 14 lbs. depending on application
Well suited for Stage 1 and Stage 2 clutch kit applications
Forged Aluminum Flywheel
Qualities of the CCI Forged Aluminum flywheel:
A. Grade 8 Aircraft quality friction surface bolts.
B. Course ground surface to maintain coefficient of friciton.
C. Stepped pin to maintain plate balance and placement.
D. Tig-welded safety tab to eliminate ring gear seperation.
E. Heilicoil bolt holes to insure proper torque value and eliminate thread damage.
Allows engine to more rapidly transfer power to the drive train and to have quicker throttle response. Motor will rev faster under acceleration. Reduces typical turbo "lag" with turbo-charged engines. Increases supercharger efficiency due to less parasitic drag on the crank. Improves mid-range torque in normally aspirated engines.
Meets and exceeds SFI spec 1.1 and 1.2
CCI Race Series Twin Disc
Competition Clutch provides the most economical racing clutch for the active sport compact enthusiast and is the preferred assembly for the professional racer. We currently offer our 4140 Forged Steel Flywheel with this unit to ensure durability in extreme racing conditions.
The CCI Twin Disc delivers uncompromised reliability and performance. All assemblies are plug and play with no additional modifications required in the transmission. Guaranteed to provide simplicity in installation and inexpensive component repair and replacement.
Makes and models available include:
Acura/Honda B/H/K Series
Dodge Neon *currently in development*
Mazda Rx7
Nissan KA/SR20DET/RB20&25
Toyota Celica/MR-2
Volkswagen VR6 *currently in development*
Contact me via PM, AIM Boostfed12, email terry@boostfed.com or call me (757)343-1123
Take Credit Cards or Paypal paypal@boostfed.com
Modified by Boostfed.com at 6:04 PM 4/10/2008
Modified by Boostfed.com at 6:59 PM 5/28/2008
Mazda Rx7
Toyota Celica/MR-2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki11a8ee »</TD></TR><TR><TD CLASS="quote">pm price on h22 twin disc
thanks</TD></TR></TABLE>
PM'ed
BUMP
PM'ed
BUMP
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramtyper19 »</TD></TR><TR><TD CLASS="quote">price for stage 2 shipped to 06095
B series, D or K Series??
</TD></TR></TABLE>B series, D or K Series??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed.com »</TD></TR><TR><TD CLASS="quote">
B series, D or K Series??</TD></TR></TABLE>
B series
B series
B series
Check your PM sir
B series
</TD></TR></TABLE>Check your PM sir
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WarpFactorVIII »</TD></TR><TR><TD CLASS="quote">pm me price for stage 1 street for a 90-93 b series integra shipped to 34453</TD></TR></TABLE>
PM'ed
PM'ed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silvercivic_ex-t »</TD></TR><TR><TD CLASS="quote">how much for a stage 4 6 puck sprung for d16y8 shipped to 02745?</TD></TR></TABLE>
PM'ed
PM'ed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaownr »</TD></TR><TR><TD CLASS="quote">can i get a quote for comp clutch 1620 and 11lbs flywheel? </TD></TR></TABLE>
PM'ed
PM'ed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaownr »</TD></TR><TR><TD CLASS="quote">just received kit, very good customer service. Kit came as said 2-3 days very good info from terry will do buisness again. </TD></TR></TABLE>
Modified by Boostfed.com at 3:38 PM 4/4/2008
