wiring spal fan ?
Old Aug 4, 2007 | 08:04 AM
vti444's Avatar
Default wiring spal fan ?
spal has 1 blue and 1 black wire, oem wiring that it needs to be connected to is black and 1 is black with red stripe
which connects with which ?
Old Aug 4, 2007 | 08:23 AM
gsxr1k05's Avatar
worst case if you hook them up backwards your fan will sping the wrong way. if this happens switch what you did.
Old Aug 4, 2007 | 08:45 AM
CEMAYHALL's Avatar
Default Re: wiring spal fan ? (vti444)
depends if you want a push or pull fan? Are you mounting the fan in the front of the radiator or in the stock location?
Old Aug 4, 2007 | 08:53 AM
vti444's Avatar
Default Re: wiring spal fan ? (CEMAYHALL)
mounting in stock location so i guess air is drawn in from outside
Old Aug 4, 2007 | 11:07 AM
vti444's Avatar
ive just stuck them together with a connector, fitted a C&r rad so problem is that im unlikely to get to temp where fan kicks in so aint gonna know if it works, looked at fan switch but says you have to have the thermostat as well for it to work
will have to just see what temps are now and make decision on thermostat and switch from there
tigerwing
May 28, 2010 09:25 AM
Corksil
Dec 9, 2009 06:56 PM
quick_ls
Mar 9, 2006 05:56 PM
pub
Jun 10, 2003 09:47 AM
Vitt1
Aug 19, 2001 06:49 AM
