Need help on EK Coupe( turns over but won't start)!!
Old Aug 4, 2007 | 02:34 AM
couped_jdm's Avatar
Default Need help on EK Coupe( turns over but won't start)!!
I have a 97 civic ex coupe, d16y8, so it is obd2a and One morning i went to start the car and it just turned over.... the fuel pump is kicking on, and there is no spark... I changed the distributor and there still was no spark. Could this be the ecu? or what else could it be? im thinkin it is an electrical issue and was thinking it would be the main relay which controls the fuel pump, cause i thought it controlled the spark also but i wouldnt think the fuel pump would still kick on... any suggestions??? thanks guys
Old Aug 4, 2007 | 04:32 AM
ru7's Avatar
ru7
Alternator fuse maybe (7,5A), any CELs?
Old Aug 4, 2007 | 08:07 AM
red ej's Avatar
Default Re: Need help on EK Coupe( turns over but won't start)!! (couped_jdm)
bump cause im having the same problem i need my car to start and stay on
Old Aug 4, 2007 | 08:12 AM
jonathan13's Avatar
Default Re: Need help on EK Coupe( turns over but won't start)!! (red ej)
swap the ecu and see if that helps, if your pump is kicking on your main relay should be ok
Old Aug 4, 2007 | 09:10 AM
couped_jdm's Avatar
I checked all of the fuses under the hood and under the dash... so is the ecu the only other option???
Old Aug 4, 2007 | 09:12 AM
couped_jdm's Avatar
Oh and the i cant get the car to start so i cant see if there is a CEL , i just get the normal kicking on of the CEL like any other time you try to start the civic when it ran perfect
Old Aug 4, 2007 | 11:21 AM
chuisek9's Avatar
Default Re: (couped_jdm)
check for the ecu fuse on the engine bay!!and if it dont work the is your distributor or blaster inside!!
Old Aug 7, 2007 | 10:19 PM
couped_jdm's Avatar
all fuses and everything in the distributor is good... anything else it could be? still havent tried a new ecu but anything else?
Old Aug 7, 2007 | 11:14 PM
highrev98civic's Avatar
are all your sensors pluged in? mainly the TPS and the IACV? mainly because the look exactly alike and will plug into each other. i just did a motor swap and if you switch the two the car runs like **** and has a hard time turning over but once you switch them the car runs perfectly fine!
Old Aug 7, 2007 | 11:23 PM
BigDeal's Avatar
make sure fuel is getting there. just because you hear the pump clicking doesnt mean its sending fuel. Other wise follow the electrical from spark plugs back to the key. You'll find your prob between the two.
Old Aug 7, 2007 | 11:36 PM
1995Civic's Avatar
This sounds like a bad Ignition Coil...
but you said you changed the entire dizzy?
My guesses were the Coil, main relay, or fuses.
Are your plugs/wires good?
Old Aug 8, 2007 | 02:04 AM
xXSilentScreamXx's Avatar
Default Re: (1995Civic)
damn you 95 yupp sounds like coil
antsoslow
31
Oct 31, 2018 06:20 AM
Tatooine
Jun 27, 2010 07:00 PM
slow88crx
Apr 11, 2008 04:20 PM
hotinteggy
Oct 22, 2007 04:44 PM
