fucked something up
Old Aug 3, 2007 | 10:43 PM
290allen's Avatar
Default fucked something up
basically the other night i was driving home and a oem motor mount bolt sanpped, yeah that was shitty, but the bolt also fell into my timming cover and got logged destroyed my belt and my timing belt slipped about 6 teeth is what im guessing, anyways since then i have replaced the timing belt and reset the timing. and it feels like i am missing about 30hp. i dont think that i bent any valves because there is no noise coming from the head, and it idles fine, but it is hard for it to go above 5000 rpm.
btw my car is a 91 std hatch with a d15b2 and a si trans.
thanks in advance any ideas welcome
Old Aug 4, 2007 | 06:31 AM
danmdevries's Avatar
Default Re: fucked something up (290allen)
Timing off? Double check it.
Just because you hear no noise doesn't mean damage hasn't been done. If you double check the timing and everything's mint, it's time to pull the head.
Old Aug 4, 2007 | 06:34 AM
1991civicsi's Avatar
Default Re: fucked something up (danmdevries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmdevries &raquo;</TD></TR><TR><TD CLASS="quote">Timing off? Double check it.
Just because you hear no noise doesn't mean damage hasn't been done. If you double check the timing and everything's mint, it's time to pull the head. </TD></TR></TABLE>
Old Aug 4, 2007 | 06:52 AM
white90rexsi's Avatar
Default Re: fucked something up (1991civicsi)
Before you go pulling the head, you can easily tell if you bent some valves,
1.Hook a vacume gauge up and see if it reads unnormal "easiest" The needle should stay steady around 22
2. Compression test each cylinder, If you have a bent valve the comression will be down.
3. Do a leak down test on each cylinder.
-Chris
Old Aug 4, 2007 | 11:47 AM
290allen's Avatar
Default Re: fucked something up (white90rexsi)
thanks for the help ill double check my timing tonight
JDMoMo
Dec 29, 2005 04:45 PM
ka0s187
Dec 14, 2005 12:25 PM
greddytointegrate
Oct 15, 2005 06:05 PM
hatchinprogress
10
Jul 14, 2005 04:46 PM
sslude
Jun 25, 2004 07:53 AM
