how do i remove my fuel pump
Old Aug 3, 2007 | 09:22 PM
B Series JuNky's Avatar
Default how do i remove my fuel pump
90 integra, how do i remove the fuel pump out the tank thanks for any help
Old Aug 3, 2007 | 11:00 PM
dc2415's Avatar
Default Re: how do i remove my fuel pump (B Series JuNky)
check out mac_24_seven's build, somewhere in his thread is a fuel pump diy, along with lots of other good diy's for integras
Old Aug 4, 2007 | 12:10 AM
numbnuts22715's Avatar
edit:
bad info. i apologize.
Modified by numbnuts22715 at 2:23 AM 8/5/2007
Old Aug 4, 2007 | 03:25 AM
r3v da t3g's Avatar
Default Re: (numbnuts22715)
oh no no no not that easy ********. you are going to actually have to drop the gas tank. In DA's the fuel pump sucks to change. check out g2ic.com they should have a DIY.
Old Aug 4, 2007 | 11:14 PM
dc2415's Avatar
Default Re: (r3v da t3g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r3v da t3g &raquo;</TD></TR><TR><TD CLASS="quote">oh no no no not that easy ********. you are going to actually have to drop the gas tank. In DA's the fuel pump sucks to change. check out g2ic.com they should have a DIY.</TD></TR></TABLE>
oops sorry for the wrong info that i posted, didnt know the difference between da dc fuel pump
Old Aug 4, 2007 | 11:23 PM
Default Re: (dc2415)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2415 &raquo;</TD></TR><TR><TD CLASS="quote">
oops sorry for the wrong info that i posted, didnt know the difference between da dc fuel pump</TD></TR></TABLE>
same for me.. i was under the impression it would be close to the same. my bad for wrong info.
Old Aug 5, 2007 | 12:50 PM
i checked g2ic.com couldnt find nothing im gonna sign up to that & post a thread see whats up.. have u ever changed a fuel pump in a DA. r3v da t3g ... i was told i didnt have to pull down the tank someone said it pulls out from under the back seat ???
Old Aug 5, 2007 | 12:52 PM
Default Re: (B Series JuNky)
im gonna be getting my fuel pump tomarrow hopfully i find a way to do this
Old Aug 5, 2007 | 10:43 PM
r3v da t3g's Avatar
the fuel pump in the back seat method is only for DC's no DA's. Yes i have replaced my fuel pump and trust me it's harder then just taking back seat off and unscrewing acouple bolts and ta da. The hardest part for is was to dissconnect everything attaching to the tank itself. Be sure to drain the tank which there is a drain plug, located driver side of the tank.
Old Aug 6, 2007 | 10:20 PM
well i changed out the fuel pump and now gas is flowing, putting the gas tank in was a b*tch and plus i was doing it myself but it worked out coo. my injecters where leaking gas im guessing i gotta change my o ring's
thedudefromjerz
Nov 5, 2007 10:02 AM
accordredliner
Feb 26, 2006 02:41 AM
90si_mugen_crx
Apr 11, 2005 01:07 AM
faSHOwidIT
Apr 7, 2005 03:36 PM
shawn_crx
Mar 8, 2005 06:35 PM
