turbo crx wont star
Old Aug 3, 2007 | 09:17 PM
bpr00civicsi's Avatar
Default turbo crx wont star
Ive got a 89 si i built the motor from the ground up and its built strong. My problem is the car wont start it turns over but it will not start. Im getting fuel and fire but still nothing. their is no check eng light on. starter is new dist is also new fuel pump is new injectors new every part is new accept comp and wire harn. i havent messed with the timing accept for the adj cam gear is retarded two deg to make up for the block being resurfaced. the timing belt would not line up it was off one to two teeth. I need help.
ED9CRX209
25
Sep 30, 2012 01:34 PM
jeryhawj
Jul 13, 2011 09:44 AM
TimCrxSir
Apr 4, 2011 05:21 PM
Harold Fulton
Oct 15, 2009 06:45 PM
bpr00civicsi
Jan 31, 2008 08:05 AM
